Oldtimeri => Općenito => Autor teme: emilijanenko - 18 Ožujka, 2011, 15:58:28
Naslov: DOT guma ?
Autor: emilijanenko - 18 Ožujka, 2011, 15:58:28
DOT F3 VC EBC Y398
jel ovo 3. misec 98?
pozdrav
Naslov: DOT guma ?
Autor: Prec - 18 Ožujka, 2011, 16:50:03
ne, na drugoj strani gume mora biti DOT od cetri broja
Naslov: DOT guma ?
Autor: emilijanenko - 18 Ožujka, 2011, 17:00:20
nema ga. mislin da je oznaka od 4 broja uvedena tek od 2000. g
Naslov: DOT guma ?
Autor: deda - 18 Ožujka, 2011, 18:13:41
Dot nije datum,nego homologacija i nema veze sa dotom datum.
Naslov: DOT guma ?
Autor: emilijanenko - 18 Ožujka, 2011, 20:46:12
The DOT Code begins with the letters "DOT" followed by a plant code (two numbers or letters) that identifies where it was manufactured. The last four numbers represent the week and year the tire was built. A three-digit code was used for tires manufactured before the year 2000. For example, 178 means it was manufactured in the 17th week of 8th year of the decade. In this case it means 1988. For tires manufactured in the 1990s, the same code holds true, but there is a little triangle (Δ) after the DOT code. Thus, a tire manufactured in the 17th week of 1998 would have the code 178Δ. In 2000, the code was switched to a 4-digit code. Same rules apply, so for example, 3003 means the tire was manufactured in the 30th week of 2003.
Naslov: DOT guma ?
Autor: goran16v - 18 Ožujka, 2011, 22:52:52
Ovo bi eventualno mogla biti 39 sedmica 98 sto je negdje 9 mjesec 98 godine, mada se nisam sretao sa slovnom oznakom i kodu vremena proizvodnje. Nedavno sam se susreo sa primjedbom ustaljenog naziva "DOT Code" prema kojem se taj naziv pogresan jer "DOT" oznaka na gumi znaci da je guma uradjena prema standardima US Department of Transport i da moze biti koristena u Americi, te da bi ispravan izraz bio "Tire Code". Guma moze imati sve ostale oznake osim skracenice "DOT" ali se ne moze prodavati u Americi. Za prodaju u Europi vazi ECE simbol koji dokazuje da je guma uradjena prema EU standardima. Velika vecina guma se proizvodi za globalna trrzista i ima obje oznake.
Naslov: DOT guma ?
Autor: gogot4 - 19 Ožujka, 2011, 11:17:34
i na mojima piše 100R pretpostavljam 1 tjedan 2000? Zna li netko nešto više?
Naslov: DOT guma ?
Autor: Prec - 19 Ožujka, 2011, 16:38:11
Ovo sam ti napisao jer na novijim gumama s jedne strane je takva nekakva sifra slicna ovoj a na drugoj strani brojke.
Naslov: DOT guma ?
Autor: goran16v - 21 Ožujka, 2011, 21:35:27
Godina proizvodnje ne mora biti na obje strane gume, vec na jednoj, pogotovo ako ima unutarnju i vanjsku stranu ili smjer.
Naslov: DOT guma ?
Autor: goran16v - 21 Ožujka, 2011, 21:40:35
Citat: gogot4;224901
To ne bi trebalo biti god proizvodnje. God proizvodnje je obicno nekako uokviren i izmaknut, ovo bi mgoa biti dio koda koji definise proizvodjaca itd.
Naslov: DOT guma ?
Autor: SCARY - 21 Ožujka, 2011, 21:55:06
tjedan i godina proizvodnje se uobičajeno smješta s unutarnje strane - zato jer je manje izložena oštećenjima...
Naslov: DOT guma ?
Autor: goran16v - 22 Ožujka, 2011, 08:28:56
Citat: SCARY;225386
Vjerovatno je tako na gumama koje imaju obiljezenu vanjsku i unutarnju stranu, na gumama koje imaju samo smijer rotacije (npr. Eskimo S3) oznaka ce na jednoj strani auta biti sa unutanje strane gume, a na drugoj s vanjske.
Naslov: DOT guma ?
Autor: RS Coupe - 23 Ožujka, 2011, 21:26:26
Neke gume su imale i slovne oznake godine proizvonje.
Inače do 2000 godine su bile 3 brojke a poslije 4.
