Oldtimeri => Struja => Autor teme: 2High - 06 Srpnja, 2011, 01:17:38
Naslov: FK automotive starter kit instalation DIY
Autor: 2High - 06 Srpnja, 2011, 01:17:38
... molim pomoć... pošto vjerujem da tu na forumu ima više električarski nadarenih od mene... jelte... nisam totalno noob, znam zalemit, izolirat i spojit i rezat žice, al u sheme ne ulazim(mada ih znam čitat donekle)...
pa krenimo... ono kaj ja imam...
1. oriđinal suzuki mk2 ignition wiring
(http://i652.photobucket.com/albums/uu244/2High99/wiring%20howto/SAM_21301600x1200.jpg)
2. bunt žica kaj sam dobil s ovim prekidačem...
(http://i652.photobucket.com/albums/uu244/2High99/wiring%20howto/SAM_21291600x1200.jpg)
3. prekidač panel (dakle, ima za prekidač dve pozicije i ovaj gumb)
(http://i652.photobucket.com/albums/uu244/2High99/wiring%20howto/SAM_21251600x1200.jpg)
pa još malo prekidača... e sad, ak se ne vidi dobro i ak slučajno trebaš bolje fotke, slobodno javi, pa bum spočetka poslikal...
(http://i652.photobucket.com/albums/uu244/2High99/wiring%20howto/SAM_21231600x1200.jpg)
(http://i652.photobucket.com/albums/uu244/2High99/wiring%20howto/SAM_21221600x1200.jpg)
(http://i652.photobucket.com/albums/uu244/2High99/wiring%20howto/SAM_21241600x1200.jpg)
4. relej
(http://i652.photobucket.com/albums/uu244/2High99/wiring%20howto/SAM_21261600x1200.jpg)
(http://i652.photobucket.com/albums/uu244/2High99/wiring%20howto/SAM_21271600x1200.jpg)
(http://i652.photobucket.com/albums/uu244/2High99/wiring%20howto/SAM_21281600x1200.jpg)
A evo i kak ide wiring(tj. kombinacija za određenu radnju) na swikiju...
(http://i652.photobucket.com/albums/uu244/2High99/wiringignition.jpg)
E sad... kam kaj treba spojit jelte???:confused:
NAPOMENA: na autu nemam više bravu(skršil ju dole, i bez brige, riješil i onaj lock na letvi, dok nema ključa u bravi), tak da mi ne igra ona da okrenem ključ i stisnem gumb i te spike... a i to mi je debilno... dakle, sve mora biti samo na prekidač i gumb...
Autor: MTX - 10 Srpnja, 2011, 11:02:31
Pa na prekidac ulaz moras dovest trajno napajanje tj po shemi W/G, sa donje strane prekidaca bi trebao spojit kad ga stavis na ON da su povezane BI B/BI Y/B i G (za G-G ne kuzim da li ima napajanje na njemu ili ih samo prespoji), te na dugme od starta bi trebalo dodat B/Y i B (opet B-B je upitno da li ima napajanje ili ih samo prespoji). I tako bi trebalo funkconirat sve normalno osim sto neces imat zastitu da ne mozes upalit starter dok motor radi.
