Oldtimeri => Oldtimer garaža => Autor teme: rumenakadulja - 23 Listopada, 2011, 16:38:54
evo moj kadet c 1.2 (1977)kupljen ovo ljeto u dosta dobrome stanju
više manje u njemu je sve standardno u međuvremenu je lakiran nije ispalo savršeno ali kako bi se reklo koliko para toliko muzike
evo neke slike s početka
(http://s4.postimage.org/2f96rk290/100_2184.jpg) (http://postimage.org/image/2f96rk290/)
(http://s4.postimage.org/2fac3zqlg/100_2187.jpg) (http://postimage.org/image/2fac3zqlg/)
prag trul
(http://s4.postimage.org/2fbrdnhwk/100_2254.jpg) (http://postimage.org/image/2fbrdnhwk/)
(http://s4.postimage.org/2fc2yexd0/100_2236.jpg) (http://postimage.org/image/2fc2yexd0/)
Ovo je trenutno stanj:
auto je lakiran prag promjenjen (zamjenski - tokić) promjenjeni filteri, svjećice, ulje
sve je u funkciji od grijanja zadnjeg stakla do pumpica za vodu
(http://img256.imageshack.us/img256/4/p1410111718.jpg) (http://imageshack.us/photo/my-images/256/p1410111718.jpg/)
(http://img683.imageshack.us/img683/8092/p141011170302.jpg) (http://imageshack.us/photo/my-images/683/p141011170302.jpg/)
(http://img833.imageshack.us/img833/6190/p141011170201.jpg) (http://imageshack.us/photo/my-images/833/p141011170201.jpg/)
(http://img687.imageshack.us/img687/1016/p141011170003.jpg) (http://imageshack.us/photo/my-images/687/p141011170003.jpg/)
(http://img830.imageshack.us/img830/4752/p141011170002.jpg) (http://imageshack.us/photo/my-images/830/p141011170002.jpg/)
(http://img841.imageshack.us/img841/6092/p1410111659.jpg) (http://imageshack.us/photo/my-images/841/p1410111659.jpg/)
(http://img593.imageshack.us/img593/1381/p061011132803.jpg) (http://imageshack.us/photo/my-images/593/p061011132803.jpg/)
(http://img844.imageshack.us/img844/1985/p0610111328.jpg) (http://imageshack.us/photo/my-images/844/p0610111328.jpg/)
Dobar Kadettić :)
lijep primjerak... sretno sa kadettom i cuvaj ga. sve manje ih je iz dana u dan
Kao novi
Odličan je, i boja mu je ludilo! Jel ostaje originalni ili imaš još neke planove s njim?
meni se čini da ih je sve više:D!
Stvarno lijep primjerak kadetta,a i meni se čini sa im se broj povećava,pa makar na našem forumu.:palac:
Predivan :)
ma izumiru lagano. to je tek par komada i oni su na forumu.. dijelovi su otisli gore i vlasnicima se ne isplati popravljat.. neracunamo pojedince koji ih imaju ko carapa u ladici:ghh:
Što bi ja onda triba reć
:)koliko ih imas?
Nijedan, iman rekorda iz 62, kažem ako je vama problem za djelove onda stvarno.:ubise:
lijepi je
super kađo stvarno je odličan, jedan savjet izbaci ove presvlake i gledaj da nađeš 2 dobra oldschool sica tipa recaro od gsi-ja ili nešto slično :palac:
A ostaje više manje orginalan sad još tražim orginalan radio pa ako ko ima po ok cijeni nek mi se javi.
Presvlake ce sigurno ici vanka al mislim da cu ostavit siceve ali idu u kožu.... kako su tvornički vec pola u koži taj crni dio bih ostavio a ovo šta je krpeno obložio bih u kožu boje bijele kave
hvala svima na dobrim komentarima
U planu mi je ugradit neku muziku u auto pa ako neko ima prijedlog kako izvesti ako mi može reći.
Imam pojačalo od 500w dva trosistemca od 200w i dva jednosistemca 50w i par VF-a zvučnika 5w
Jedino adekvatno mjesto za prednji par (2x50W) zvučnike su mi vrata ali nemogu se odlučiti dali da ih bušim.
A za zadnje zvučnike ( 2 x 200w ) također se nemogu odlučiti dali da bušim onu ploču iznad gepeka jer se ipak ispod nalazi rezervar.Ove male bih stavio naprijed negdje ispod nogu.
Pojačalo bih stavio ispod sjedala a na mjesto radija stavio bih orginal koji sam nabavio te njega spojio na pojačalo a i napravio bih da mogu direktno sa stika puštati muziku.
Ako mi može neko dati svoje mišljenje i ideje najviše se bojim narušiti orginalan izgled.
Ako budem bušio vrata kako se skida ručica za otvaranje prozora !?
(http://img542.imageshack.us/img542/1596/dsdff.png) (http://imageshack.us/photo/my-images/542/dsdff.png/)
Imas jedan osigurac izmedu rucice i onog okruglog plasticnog dijela koji dosjeda na vrata.Taj osigurac trebas sa tankim jako dugim sarafencigerom samo "trknuti" van i rucica sama ispadne jer ju ispod napinje feder.Treba to pokazati,malo je tesko objasniti,uglavnom,nista na silu,prvo taj osigurac van ispod rucice!
Kolega!!!!!!!!! Ručica se skida vrlo jednostavno ,samo moraš imat usku tanku ravnu kacavidu.Ima ti osigurač koji je drži za osovinu ,a naljakše ti je kacavidom sa strane između ručice i plastične šajbe provući i skinuti osigurač.On se izbija na stranu kontra od ručice.Da sam na tvom mjestu pojačalo bi stavio u gepek ,s ti m da bi napravio dasku i obložio je tapisonom ,koja bi pokrila rezervar .Obavezno odmaknut dasku barem 3 cm od rezervara ,da ne bi vite završile u njemu.Ja sam tako imao u bivšoj asconi b..Zadnje bi zvučnike ugradio pozadi ,s tim da bi prorezao lim i isto napravio ud špere (10mm) debele dasku i isto je skajem obložio .Skineš rezervar da ti je lakše odrezat lim.I Dobio si i basa dosta s time.Ja sam pozadi tako imao JBL od 20 cm ,na alpine pojačalo.Svi su mislili da imam woofer.Žrtvovao bi oplate pa bi u njih ubacio isto zvučnike ,da se popuni zvučna slika pogotovo naprijed Prednji sistem je u biti najvažniji,što se zvučne slike tiče.Tako ću i na sadašnjoj asconi napravit i na kupeu.Pogledaj slike od mog rekorda e2 od neki dan na temi od ascone a pa će ti možda biti i nešto jasnije.Pozdrav.
vidam auto ispred gradevinskog faksa u splitu,tvog i jos jednog zelenog. jel tamo studiras?
malo je zafrkan ali sam uspia "trknuti" ga :palac: hvala puno obojici na pomoći ... vidim rekorda i sviđa mi se šta vidim i fala na savjetu orginalna daska koja ide na taj lim mi je ionako katastrofa tako da bi mi to šta govoriš bilo najbolje ... koliko ti je snage ovo pojačalo u rekordu ?
srednja elektrotehnička škola sam, tu stojim u đačkom domu a zeleni mi je od rođaka isto stoji u domu.....njegov je s 4 vrata bojali smo u isto vrime. Ti studiraš tu nešto ?
Lijep kadetić,svaka čast! Vidio sam uživo tvog i onog zelenog ispred građevinskog faksa, možda si mi poznat i ja sam bio u domu 3g....pa mogli bi se nać da te upitam imaš li išta dijelova što meni fale itd.:)
kadett c conecting people :palac: nisan ti baš nešto potkovan s djelovima ali aktivno tražin još jednog kadeta šta jeftinijog i nebitno u kojem stanju za djelove i da mogu na njemu malo iz razonode radit. Vidia sam na gripama vukovarska ulica kadetta c mislim 1.0 motor onaj s okruglim svjetlima i mjenjačom dugim pa ako znaš jeli se možda prodaje?
Ono ti je 6 kanalno pojačalo i to 4x60W rms i 1x 180W rms.Sve ide preko njega i prednji i zadnji i woofer.Mala koncertna dvorana.Fulao si kolega nije "kadettc conecting people" nego "old opel conecting people":rofl:.Pozdrav iz Dubrovnika.
nemam pojma nisam vidio,znam samo za onog 4-vrata kraj doma(zeleni) da mi je znat tko je vlasnik, pa bi ga upita za branik,znaš li ti možda?
Pozdrav i tebi Ante.
A koji ti branik triba ? nece ti on to prodavati ali ima on jednog 4 vrata sa strane pa ga mogu pitati ako želiš
Koja je tvoja procjena koliko ima kadetta u splitu?.... znam kad sam krenio u školu prije 4 godine bilo ih je na sve strane sad znam za registrirane na spinutu žuti , na gripama narančasti i još vidim onog bijelog u vožnji i to je sve.
ma nisam vidio nego jednog bilog u voznom stanju kraj Jokera...:( Zadnji branik mi triba, pa se raspitaj, a slike radova auta sam stavio u garažu pa pogledaj :gosp:
I u Dubrovniku ih je sve manje,s tim ima par komada u sasvim solidnom stanju.Sve su limo sa 4 ili 2 vrata,dok cupea ima 2 kom neregistrirana.Jedan je isto zeleni i prodavao se za 2000 eura i nikad ga neće prodat te pare ,a drugi je trulex u "majstora" koji je meni lakirao rekorda cupea.Karavan je ostao jedan i nije komplet ,a dobio bi gaza 1000kn.
a pogleda san već slike vrhunske rad,on ti ima branik na ovome drugome autu al to je malo noviji pa na braniku imaju neke plastike i pitat ću ga i kad budem moga slikat ću
tog kod jokera nisam vidia ima godinu dana :(
aj može pa mi javi,hvala :gosp:
Shvatljivo je da ih s vremenom ima sve manje ali ovako naglo su nestali s ceste.2000€ je previše može se registriran u super stanju naći za te novce, meni se osobno karavan ne sviđa ništa posebno.
javit ću ti pozdrav
srednja elektrotehnička škola sam, tu stojim u đačkom domu a zeleni mi je od rođaka isto stoji u domu.....njegov je s 4 vrata bojali smo u isto vrime. Ti studiraš tu nešto ?[/QUOTE]
ja sam na gradevini, s kolegom kadett c imotski. i ja sam iz sibenika pa te zato i pitam,radim sebi 128-u...
ja sam ti u županiji Čista Velika,popunit će se parking ispred gaf-a :ghh:
:palac: a nego
imaš blizu građevinskog faksa rastavljenog kadetta, bez zadnjeg trapa sa kišobran mjenjačem, smeđe boje...tamo često prolazin jer iden u građevinsku školu...
provjeri jeli se prodaje jer je idealan za dijelove!
kadett c imotski (http://www.oldschoolhr.com/forums/member.php?4426-kadett-c-imotski) mislin da ima zadnji branik šta tebi triba, pa ako ti je usput...:pda: (http://www.oldschoolhr.com/forums/member.php?4426-kadett-c-imotski)
probavalo se vec doc do vlasnika tog kadetta,ali neuspjesno...ima tocno ono sta triba kadett c imotskom :D
Daaa ja sam totalno zaboravia na njega pa on onda tu stoji već dvi godine :sok: i ko je vlasnik ? jel ga želi prodati ? pa jednostavno ostavi papir ispod brisača... u međuvrimenu ga komunalno poduzeće može oduzeti
i boja mu je neka zlatna
kako je krenilo cini mi se da bi on moga nestat pod okriljem noci :ghh:
ahahahaha bolje da mu ga mi uzmemo nego komunalno poduzeće
samo nek on čeka...:)
jedan iz oglasa
OPEL KADETT C 1.2, 1977. g., karoserija i motor dobri, pali-vozi, cijena 300 eura.
(kontakt podaci uz pretplatu, SMS ili u tiskanom izdanju)
hvala kolega roko na prenjem znaku :gosp: i lijep pozdav
(http://i42.tinypic.com/2en7qkw.jpg)
(http://i44.tinypic.com/fxqdjb.jpg)
Nema na čemu .. tu smo da si pomažemo
zadnja slika, zeleni crveni i zlatni... hehehe... poz..!
lep kadetic cista 10:)
Neka još malo nadam se da će se i moj nać na nekoj slici zajedno s ova dva!:)
hvala,zlatni je izgleda završio na otpadu...
nadam se što prije
još jednom hvala....
Prekrasan je auto i stvarno ga čuvaj. U zadnje vrijeme su ponovo počeli izvirati na sve strane,a vidio sam da im je i cijena pošla poprilično prema gore. Tako treba i ako što zapne pitaj.Pozdrav!!!!!!!!!
Uvjeren sam da je u dobrim rukama ...
ima ih i po oglasnicima i po cestama u velikom broju...
hvala na ponuđenoj pomoći
Pozdrav i tebi
(http://s7.postimage.org/l9toxtfo7/Fotografija0054.jpg) (http://postimage.org/image/l9toxtfo7/)
(http://s9.postimage.org/nij2sbc3f/Fotografija0051.jpg) (http://postimage.org/image/nij2sbc3f/)
(http://s7.postimage.org/imihc27pz/Fotografija0056.jpg) (http://postimage.org/image/imihc27pz/)
Evo kadett je registriran kao starodobnik procjena pravljena u g. Armana (Zd) pa ako koga šta zanima nadam se da mogu pomoći...
Getriba mi je pri kraju pa me zanima kakve su mogućnosti ugradnje getribe s 5 brzina....motor je 60KS
