Oldtimeri => Oldtimer garaža => Autor teme: LeonardoL - 27 Siječnja, 2018, 17:15:10
Naslov: 1976 BMW 633CSi - donor dijelova
Autor: LeonardoL - 27 Siječnja, 2018, 17:15:10
Evo jedan posto mi fali 90% dijelova za moj.
Trulex skroz (Karmann) ali kompletan. Svi dijelovi idu s njega na restauraciju pa sa strane. Tek poslije lakiranja idu na drugog.
(https://s10.postimg.org/tridljhed/20180127_144417.jpg) (https://postimg.org/image/tridljhed/)
(https://s10.postimg.org/z2xa68vr9/20180127_144432.jpg) (https://postimg.org/image/z2xa68vr9/)
(https://s10.postimg.org/o3c2umi6t/20180127_151438.jpg) (https://postimg.org/image/o3c2umi6t/)
(https://s10.postimg.org/5mho4dmz9/20180127_162601.jpg) (https://postimg.org/image/5mho4dmz9/)
(https://s10.postimg.org/fxu0wg6sl/20180127_162605.jpg) (https://postimg.org/image/fxu0wg6sl/)
(https://s10.postimg.org/usimb7gjp/20180127_162607.jpg) (https://postimg.org/image/usimb7gjp/)
(https://s10.postimg.org/kwhjb10bp/20180127_162612.jpg) (https://postimg.org/image/kwhjb10bp/)
(https://s10.postimg.org/fwk33i2j9/20180127_162618.jpg) (https://postimg.org/image/fwk33i2j9/)
(https://s10.postimg.org/xnvphhs39/20180127_162633.jpg) (https://postimg.org/image/xnvphhs39/)
Naslov: Odg: 1976 BMW 633CSi - donor dijelova
Autor: LeonardoL - 30 Siječnja, 2018, 13:05:29
Nakon cjelojutarnjeg ciscenja gledam; pa taj interijer uopce nije los koliko je samo prljav. Dubinsko ciscenje i nekoliko sitnih rupica za popravit (osim plafona kojeg je mis preuzeo). Cak mi se svida izbjedljeli look koze. Motor vrti, elektronika zaj......<br />(http://thumb.ibb.co/hOoFB6/20180130_125419.jpg) (http://ibb.co/hOoFB6) (http://thumb.ibb.co/ib0vB6/20180130_125117.jpg) (http://ibb.co/ib0vB6) (http://thumb.ibb.co/nwQOym/20180130_125115.jpg) (http://ibb.co/nwQOym) (http://thumb.ibb.co/gEXxPR/20180130_125107.jpg) (http://ibb.co/gEXxPR) (http://thumb.ibb.co/dVxxPR/20180130_125104.jpg) (http://ibb.co/dVxxPR) (http://thumb.ibb.co/kjxmJm/20180130_125059.jpg) (http://ibb.co/kjxmJm) (http://thumb.ibb.co/eCTMjR/20180130_125047.jpg) (http://ibb.co/eCTMjR) (http://thumb.ibb.co/fo7E4R/20180130_125043.jpg) (http://ibb.co/fo7E4R) (http://thumb.ibb.co/bXaZ4R/20180130_125031.jpg) (http://ibb.co/bXaZ4R)<br />
Apsolutno svaki saraf vec 3 dana spricam sa WD40, valjda ce se dat kroz tjedan dana skinut sve i da mogu krenut slagat za drugi.
Autor: jeep frik - 30 Siječnja, 2018, 13:52:19
Imas Sonax reiniger tako nesto zuta ambalaza u kauflandu imas bas za serafe. Pročitaj na polici naci ces skuplje je nesto..Odlicna je evo mi bas na Jeep-u koristimo jos uvjek ima par serafa za skinuti. Inace mi je zelja i sestica pa cu sa veseljem pratiti temu...
Autor: LeonardoL - 30 Siječnja, 2018, 14:03:45
Hvala, buedm pogledao. 2 velika WDa sam već istresao. Tu samo pokazujem ovoga, restaurirani dijelovi idu u drugu temu, na (za sada) zelenog 633.
Autor: sven - 30 Siječnja, 2018, 14:14:58
Iako očito nema druge, baš je šteta ovakav auto rashodovat. Koliko se sjećam onaj drugi ti je limarski bolji?
Ovog donatora si uspio naći negdje kod nas?
Kaj je sa E32? Nije valjda i on na kraju puta..:resent:
Autor: LeonardoL - 30 Siječnja, 2018, 14:49:59
Da, na drugom ima max dan posla (lim). Doveo sam da iz Bad Feilnbacha, malo mjesto blizu Munchena. Trazio je 2100e auto je odjavljen 1991 i ima papire. Ali ga je dobrano pojelo od stajanja.
E32 je (bio) u jako dobrom stanju, srebrna koza 730 1990. Ali vlasnik je umro i prijepis je nemoguc. Platio ga 5000kn, reko za dijelove prodat dobar...
Autor: jeep frik - 30 Siječnja, 2018, 16:02:16
Bas dobro jer na mobile de i sl.traze po 5000 za takve i više cak. Imao si srece. Njega si uvezao znaci vec gledam ako bi ga kasnije prodavao tj.ono sto ostane, ali imas pravo pojelo ga je previse je tu posla pa ce kao donor bit idealan....
Autor: jeep frik - 30 Siječnja, 2018, 16:48:32
<br />(http://thumb.ibb.co/d4XOER/sonax_sx_90_plus_400_ml.jpg) (http://ibb.co/d4XOER)<br /><br />image for upload (http://imgbb.com/)<br />
Autor: jeep frik - 30 Siječnja, 2018, 16:49:38
Nemoguce bez tog nejde skoro...Spasilo me
Autor: LeonardoL - 30 Siječnja, 2018, 17:21:13
Hvala, pogledat cu gdje ima.
Jes imao sam srece, ima na sebi rijedak prvi tip spoilera (koji ide na prodaju, ne svida mi se a i moj nema rupa) , perace farova (300e min.), naslone zadnjih sjedala...
Autor: jeep frik - 30 Siječnja, 2018, 18:41:42
Skuzio sam perace fora su. Ajd super bas mi je zelja sestica budem vidio jednog dana imam vozila vec... Sogor je lud isto mlad decko ima volje slagat. Ima kocku 318 is i poceo nesto oko e21 jedan za djelove drugi 318 nedavno nabavio... Bio bih ti zahvalan ak slucajno negdje usput cujes za kakvu skoljku e21 320... Mozda kaj naleti povoljno prije nek kaj bi van isli vec su cjene otisle gore... Ovdje isto pomalo iako se da jos nesto.
Autor: jeep frik - 31 Siječnja, 2018, 22:56:13
E sam da kazem da netreba za e21 gledat nasli smo ga. Sutra slike stavljam. Svejedno Hvala !
Autor: LeonardoL - 10 Veljače, 2018, 20:31:34
Nakon tjedan dana muljanja po žicama, relejima i šta već oživio je.
Pali samo na sprej za sada, baca plamen nekad nazad na usis. Ventil ili paljenje.
(https://s13.postimg.org/7yqk8p8k3/20180210_201710.jpg) (https://postimg.org/image/7yqk8p8k3/)
(https://s13.postimg.org/5het1eecz/20180210_201715.jpg) (https://postimg.org/image/5het1eecz/)
(https://s13.postimg.org/ilkde118z/20180210_201834.jpg) (https://postimg.org/image/ilkde118z/)
Autor: jeep frik - 10 Veljače, 2018, 23:50:36
Stara pila pali nakon toliko godina. Dobra fora s dekom, izgleda kao da je pokriven! :shok:
Autor: LeonardoL - 11 Veljače, 2018, 10:56:04
Deka je preko prednjeg stakla i spoja haube zato sta dihtung stakla curi na vrhu i hauba se ne zatvara do kraja
Autor: jeep frik - 11 Veljače, 2018, 12:04:12
OK. Neg sjetio sam se da su znali rec da spray za paljenje nije dobar za motor. Samo u nuzdi.
Autor: LeonardoL - 11 Veljače, 2018, 13:34:46
A ko ce ga znat. Bitno mi je bilo da cujem da radi na kratko.
Autor: Bellof - 11 Veljače, 2018, 14:28:45
Neće motoru ništa bit, pogotovo jer kako pišeš drukčije ga nisi moga upalit, kratko špricanje i nemaj brige, znaju ljudi našpricat veliku količinu di bi nabilo kompresiju i tu bi nastali problemi, dodatni troškovi na motoru.
Pokušaj ubacit 3.5 motor jer ovi 2.8 i 3.3 su jaaako osjetljivi, i kad se napravi kompletna generalka kod tih starih BMW motora koji se vole zavrtit u đire često prosviraju leteči, pucaju blokovi ....
Autor: LeonardoL - 11 Veljače, 2018, 15:15:01
M30B32 (633) i M30B34 (poslije 1982 635) su u biti identicni motori, ista glava ali provrtani cilindri. Izuzev ranih 635 (M90). Ako mi M90 padne u ruke i dalje bi ostavio ovaj blok i glavu ali ubacio bregastu iz M90.
Ovaj ce ostat ali ce biti malo doraden, jako malo skinuta tezina sa zamasnjaka i prosireni kanali u glavi i oko ventila.
Nikad nisam cuo da blokovi pucaju ali glave zato vole.
Kad je vec 633 nek ostane.
Autor: Žein - 11 Veljače, 2018, 15:24:02
M90 ti je visokoturazni motor za razliku od M30
Autor: Bellof - 11 Veljače, 2018, 16:45:52
Malo o povijesti i činjenicama, 70-tih godina BMW je ima u ponudi te šestake koji su se pokazali loši, zahvaljujući Alpini koji su dokazali da jedino 3.5 trpi  zlostavljanje bez pogovora i u BMW-u su svatili da je najbolje "gurat" tu priču sa 3.5 litre.
Za koji god ti motor se odlučia, ja poštujem, samo ti njega završi.
Autor: jeep frik - 11 Veljače, 2018, 17:23:43
Bas tako sam ga napravi. Da vidimo makinu(jos jedan koji bi ja u kolekciji).Nece se on sutra odma razletit to je sigurno. Ni skoro. Na spray sam mislio rec nemoj cesto ga palit. Inace su kasniji 24-ventilci puno  bolji. Opet kako kome pa o tom potom.
Autor: jeep frik - 11 Veljače, 2018, 17:26:10
Ako di zapne javi prijatelj ih radi u Jaski sto znas vec i sam vjerovatno. Full korektno cijene i usluga. Jedino boli glava kad ode neki skuplji dio za mjenjat.
Autor: LeonardoL - 12 Ožujka, 2018, 17:01:08
Malo toplije pa malo raskopavanja.
Most je bolji nego sta sam ocekivao. Pjeskarenje to je to.
(https://s18.postimg.org/vfae4kzn9/20180312_165201.jpg) (https://postimg.org/image/vfae4kzn9/)
(https://s18.postimg.org/4u7v90hud/20180312_165207.jpg) (https://postimg.org/image/4u7v90hud/)
(https://s18.postimg.org/44p2wh1th/20180312_165219.jpg) (https://postimg.org/image/44p2wh1th/)
(https://s18.postimg.org/5jqnl60bp/20180312_165223.jpg) (https://postimg.org/image/5jqnl60bp/)
Autor: LeonardoL - 16 Ožujka, 2018, 16:22:57
Most dole...
<br />(http://thumb.ibb.co/kpZSuc/20180315_173104.jpg) (http://ibb.co/kpZSuc)<br />
Autor: LeonardoL - 27 Ožujka, 2018, 19:27:27
Tank ko nov!
U smeće. Źačudo, našao sam firmu u zagrebu šta ih radi na novo po narudžbi. Oko 1800kn za keš
(https://s17.postimg.org/w8k2f4ekb/20180327_164012.jpg) (https://postimg.org/image/w8k2f4ekb/)
(https://s17.postimg.org/am51y2suj/20180327_164027.jpg) (https://postimg.org/image/am51y2suj/)
Autor: Pranja - 27 Ožujka, 2018, 21:47:38
Hoće li novi biti inox?
Autor: LeonardoL - 27 Ožujka, 2018, 23:27:18
Rekao mi je farbani lim. Ali na stranici im pise lim ili ALU. Vidjet cu kad odem tamo,ceka se 15 dana jer ih rade kad se naruce.
Ako je neki znj onda cu iz Wallothnestcha uzet.
Autor: sven - 28 Ožujka, 2018, 08:55:12
Slobodno otkrij podatke o toj firmi, radi li po uzorku ili nacrtima, izrađuju li i neke druge dijelove itd. Moglo bi i drugima biti od pomoći...:blink:
Autor: Bernardtkalcec - 30 Ožujka, 2018, 19:41:52
Imam Pitanje u Vezi rezervara???
1800Kn čiščenje tanka ili pravljenje novoG?
Hvala
Autor: taxi80 - 30 Ožujka, 2018, 19:49:37
Bernard,gas u u rubriku  novi članovi  predstaviti se,inače budeš padobranac godine...
Autor: LeonardoL - 31 Ožujka, 2018, 08:07:39
Izrada novog tanka.
Broj je 013496102 ali imena firme se nemogu sjetit :cofee:
Autor: Mihajlo - 31 Ožujka, 2018, 22:27:52
to je negdi na samoborskoj cesti ako me broj ne vara...?
Autor: cona - 31 Ožujka, 2018, 22:40:38
Po pretraživanju broj je od Hrupelj d.o.o.
Autor: LeonardoL - 21 Kolovoza, 2018, 11:17:09
Izvadim dijelova još i ide u smeće... ako nekom treba limarije, njuška nek se javi pa se dogovorimo da ne bacam. Ima još ok dijelova limarije. Ima i papire
(https://s15.postimg.cc/z27cvmccn/20180815_142425.jpg) (https://postimg.cc/image/z27cvmccn/)
(https://s15.postimg.cc/f7lb9j7fr/20180815_142431.jpg) (https://postimg.cc/image/f7lb9j7fr/)
(https://s15.postimg.cc/os4xwderb/20180815_142438.jpg) (https://postimg.cc/image/os4xwderb/)
(https://s15.postimg.cc/3v8prqblj/20180815_142444.jpg) (https://postimg.cc/image/3v8prqblj/)
(https://s15.postimg.cc/ly1siymvr/20180815_142454.jpg) (https://postimg.cc/image/ly1siymvr/)
(https://s15.postimg.cc/w6u9p4iqv/20180815_142534.jpg) (https://postimg.cc/image/w6u9p4iqv/)
Autor: LeonardoL - 21 Listopada, 2018, 16:52:27
Ostaci ostataka
Ako netko treba dijelove limarije nek ga vozi.
Kroz mjesec dana ide pod prešu. Papiere vorhanden
(https://i.postimg.cc/Xr17WvBz/20181021-161015.jpg) (https://postimg.cc/Xr17WvBz)
(https://i.postimg.cc/cvL4P3C3/20181021-161022.jpg) (https://postimg.cc/cvL4P3C3)
(https://i.postimg.cc/xcR1s5fY/20181021-161027.jpg) (https://postimg.cc/xcR1s5fY)
(https://i.postimg.cc/rR5KFL2t/20181021-161037.jpg) (https://postimg.cc/rR5KFL2t)
Autor: Igor V. - 21 Listopada, 2018, 19:37:39
Jel ima taj auto L jetronic?
Trebao bi relej pumpe?
Autor: LeonardoL - 21 Listopada, 2018, 22:09:17
Imao je
Pumpe goriva? To je onaj "standardni" relej koji se koristi svugdje u autu
