Oldtimeri => Oldtimer garaža => Autor teme: Dzele - 21 Prosinca, 2020, 14:35:38
evo mog projekta i trenutacno stanje radi se o porsche-u 924 je da je vise audi i vw nego porsche ali meni pase hehe
<br />(https://i.ibb.co/GkmVdGg/IMG-20201115-WA0003.jpg) (https://ibb.co/GkmVdGg) (https://i.ibb.co/hgMVN9M/IMG-20201116-WA0003.jpg) (https://ibb.co/hgMVN9M) (https://i.ibb.co/kgmz91V/IMG-20201115-173113.jpg) (https://ibb.co/kgmz91V) (https://i.ibb.co/D9Zr6Yx/IMG-20201118-142302.jpg) (https://ibb.co/D9Zr6Yx) (https://i.ibb.co/yfbwzxG/IMG-20201118-163206.jpg) (https://ibb.co/yfbwzxG) (https://i.ibb.co/k1LW4Kx/IMG-20201118-163215.jpg) (https://ibb.co/k1LW4Kx) (https://i.ibb.co/9NrPsTN/IMG-20201118-163221.jpg) (https://ibb.co/9NrPsTN) (https://i.ibb.co/Lp9sM0h/IMG-20201118-163326.jpg) (https://ibb.co/Lp9sM0h) (https://i.ibb.co/d0K81JH/IMG-20201118-163330.jpg) (https://ibb.co/d0K81JH) (https://i.ibb.co/d0x5wR0/IMG-20201118-WA0004.jpg) (https://ibb.co/d0x5wR0) (https://i.ibb.co/Gx0L6B1/IMG-20201129-155301.jpg) (https://ibb.co/Gx0L6B1) (https://i.ibb.co/KNPr3S2/IMG-20201129-155309.jpg) (https://ibb.co/KNPr3S2) (https://i.ibb.co/94GhKJS/IMG-20201213-144356.jpg) (https://ibb.co/94GhKJS) (https://i.ibb.co/3hXd9YG/IMG-20201213-160907.jpg) (https://ibb.co/3hXd9YG) (https://i.ibb.co/T8PCN6Z/IMG-20201213-161045.jpg) (https://ibb.co/T8PCN6Z)<br />
Nebitno ko je kome "gazda" , i što drugi misle i kažu, bitno je da tebi paše i da si ti zadovoljan.
Samo naprid.
Samo naprid.
je pa normalno,mada vjerujem da su ljudi na ovom forumu normalni pa ono
Bit ce zanimljiv na cesti, ko kap u moru od hrpe novoga 'smeca'! :good:
pa...da bit ce dosta zanimljiv autic na cesti...samo nece bit ko nov posto ga planiram i vozit :biggrin2:
samo naprijed, čista serijala, dobro ga utegni i biti će super :good:
Zanimljiv(ij)a su "ambulantna kola" iza.... :umnik2:
jesu zanimljiva ali nisu moja kola hehehe ali i trulex zesci hehe
OK je Pors, ali ovaj Fiat 238 Ambulanza je bas raritetan i zanimljiv, dapace ludo dobar, a sad dali ima potencijala za uredit neki mali kamper od njega ili u serijali je upitno, takvi rariteti nisu nazalost popularni medju narodom, normalno da se pale na sportska kola a ne na staru hitnu pomoc!! Jel poznat vlasnik ili je divljak, ima li papire, to je valda doslo ko pomoc iz Italije 90-tih?? Daj ga malo poslikaj , mozes i temu otvorit, mozda bude kupaca kad ga ljepo predstavis..... Ovako to izgleda kad je auto u sluzbi: http://www.croceverdecivitanova.it/autoambulanza-fiat-238/
Dobra, dobraaa :lol:
ha poznat je vlasnik al ga on ne prodaje jel ce ga kao slagat a stoje vec 3 cak mozda i 4 godine a kad je dosla na dvore na "cuvanje" vec je bila u raspadnom stanju uprincipu napravit cu nekakvu temu preksutra kad cu moc po svijetlu poslikat kola,da su u boljem stanju vec bi ja nagovaro vlasnika da mi proda ali po meni se ne isplati jbg
sta ocete rec s time da...pa dobro ajde ispravak na pola normalni hehehe :P
Fora je porš, nekad ih je bilo za vidjeti , al ja se ne sjećam kad sam ga zadnji put vidio , sretno s radovima i nadam se da će ostati u ovoj lijepoj crvenoj boji
normalno da ce ostat crvena ljepo mi izgleda boja :yes:
evo nisam bas sa vremenom pa...uglavnom neki napredci od zadnjeg puta glava obrađena slozeni cepovi za k jet dizne posto se bacam na frgice normalno m12 navoj i seraf pa se seraf zaoblil sagladil u kanalu,nabavljen komplet ovjes od 944 modela sa jacim kocnicama(fale mi zadnja kliješta pa ako neko ima nek se javi hvala) ali to vjerojatno iduce godine ide na auto,944 zadnja hauba,kardan posto je moj puknut,bregasta i podizaci,jos trebam kuplung i frgice nabavit,pa mogu slozit sve nazad i paljba
(https://i.postimg.cc/YjTFtkT5/IMG-20210922-213053.jpg) (https://postimg.cc/YjTFtkT5)
(https://i.postimg.cc/DSTbb6v5/IMG-20210922-213123.jpg) (https://postimg.cc/DSTbb6v5)
(https://i.postimg.cc/Lq4YxsZ1/IMG-20210922-213205.jpg) (https://postimg.cc/Lq4YxsZ1)
(https://i.postimg.cc/yk9ZdtHk/IMG-20210922-213208.jpg) (https://postimg.cc/yk9ZdtHk)
(https://i.postimg.cc/8s7W8sXd/IMG-20210922-213213.jpg) (https://postimg.cc/8s7W8sXd)
(https://i.postimg.cc/TKJ5jbhx/IMG-20210922-213236.jpg) (https://postimg.cc/TKJ5jbhx)
(https://i.postimg.cc/QFy03vkV/IMG-20210922-213254.jpg) (https://postimg.cc/QFy03vkV)
Vidio neki dan kod Živića 924 za dijelove pa sam te se sjetio, nije bilo glasa od prošle godine. Ipak napreduju radovi! :good:
Ima jedan 924 iza caffe bara BMW u Trsteniku Nartskom (par min od Ikee ZG)
Možda bi ga se moglo i restaurirat al rađe u dijelove, ima čak i klimu
a da jbg malo manjak vremena pa kad stignem nešto napravit napravim...
ha trenutno neplaniram uzet jos jednoga,ali dobro je znati ako zatreba koji dio
