Ostalo => Motocikli => Autor teme: Balkan Boy - 25 Srpnja, 2007, 19:46:25
Evo par slika koje san uspija spasit od nekih motora koje san ima; yamaha fzr 400 rr , cagiva mito 175 , gilera rc 125 , tomosi bt 90 ,
ziko RR i moj brat (jebac rumene kadulje) na apn-u 6 i njegova latašica e90.
(http://img390.imageshack.us/img390/8311/070309183225if1.th.jpg) (http://img390.imageshack.us/my.php?image=070309183225if1.jpg)
(http://img329.imageshack.us/img329/8334/dsc03440lk0.th.jpg) (http://img329.imageshack.us/my.php?image=dsc03440lk0.jpg)
(http://img329.imageshack.us/img329/4535/dsc03439tm4.th.jpg) (http://img329.imageshack.us/my.php?image=dsc03439tm4.jpg)
ovaj motor sam proda jednom liku u splitu i nakon par dana mu ga je ukralo , a ja sam još vlasnik u papirima tj. nisam ga prepisa pa ako neko nešto zna o njemu neka javi
(http://img329.imageshack.us/img329/1807/dsc02131yf9.th.jpg) (http://img329.imageshack.us/my.php?image=dsc02131yf9.jpg)
(http://img329.imageshack.us/img329/7148/dsc02134cl6.th.jpg) (http://img329.imageshack.us/my.php?image=dsc02134cl6.jpg)
(http://img329.imageshack.us/img329/6857/dsc02672ka6.th.jpg) (http://img329.imageshack.us/my.php?image=dsc02672ka6.jpg)
(http://img329.imageshack.us/img329/4611/dsc02711ub6.th.jpg) (http://img329.imageshack.us/my.php?image=dsc02711ub6.jpg)
(http://img329.imageshack.us/img329/9055/dsc02669du1.th.jpg) (http://img329.imageshack.us/my.php?image=dsc02669du1.jpg)
(http://img329.imageshack.us/img329/1878/dsc03454bi6.th.jpg) (http://img329.imageshack.us/my.php?image=dsc03454bi6.jpg)
(http://img329.imageshack.us/img329/1691/dsc03455yy4.th.jpg) (http://img329.imageshack.us/my.php?image=dsc03455yy4.jpg)
(http://img329.imageshack.us/img329/7535/picture2jpgmd0.th.png) (http://img329.imageshack.us/my.php?image=picture2jpgmd0.png)
(http://img329.imageshack.us/img329/2382/picture3jpgyh0.th.png) (http://img329.imageshack.us/my.php?image=picture3jpgyh0.png)
(http://img329.imageshack.us/img329/5388/picture4jpgwn0.th.png) (http://img329.imageshack.us/my.php?image=picture4jpgwn0.png)
(http://img329.imageshack.us/img329/8018/picture22jpgtf7.th.png) (http://img329.imageshack.us/my.php?image=picture22jpgtf7.png)
(http://img329.imageshack.us/img329/7666/dsc02675hb8.th.jpg) (http://img329.imageshack.us/my.php?image=dsc02675hb8.jpg)
(http://img329.imageshack.us/img329/9416/dsc03360sn2.th.jpg) (http://img329.imageshack.us/my.php?image=dsc03360sn2.jpg)
to nije sve , stavit cu još slike završene yamahe , mito u oklopima , gileru sam do zadnjevide sredija i ispolira , svi novi djelovi , sve u šprickitu za sve to san izgubija godinu dana jer bi radija kad bi ima vrimena , iako ce te reci da se tu nema šta dirat ali mi smo fanatici ali totalni , nažalost gileru san proda najboljem prijatelju koji me pila , motor ce biti gotov ovu zimu i bit ce prava bolest , a onaj moj brat , uživljenik u poliranje i niklovanje , rastavija po motora i radi ga ponovo , prije dva dana san mu odnija felge na pjeskarenje pa ih ceka poliranje . toliko za sada , bit ce još , nadam se da vam se svida. :bye: :bye: :bye:
e bok :D ;ja doma imam tomosa bt sa masinom od elektronke 90 :P ,to sam vozio prije par godina...nije preraden ko tvoj bt,ima onu plastiku oko masine i zadnji zmigavci su pomaknuti tako da vise nisu na blatobranu kod registracije :P ...
ovaj tvoj bt mi je previse ekstreman a to mu bas ne stoji :roll ...
Ovaj bt ima upasirane zadnje vilice i centralni amortizer od CTX-a , a plastike su rucni rad , a šta kažeš na ovoga , isto proša kroz moju garažu , plastike preradene od cagive frecie
(http://img106.imageshack.us/img106/6964/dsc02662rx9.th.jpg) (http://img106.imageshack.us/my.php?image=dsc02662rx9.jpg)
ovaj mi lijepo izgleda ali neznam kak se hladi cilindar zbog tih plastika :P ...ja sam isao u darovar po bt-a sa masinom od elektronke,isto je imao sve te plastike od neke aprilije 125 po sebi al mi se pregrijavao a i plastike su lose pripasane gore,sve se klimalo :roll ...pa sam skinuo masinu i stavio na svog?obicnog? bt-a i to mi je bilo ok :agressive: !!jos imam ove plastike u vikendici;htio sam ih bolje pripasati na svog ?obicnog? bt-a ali sam odustao...
kada budeš prodavao jedno od ovo dvoje cagiva mito 125 ili gilera rc
javi mi se , jer san uvik zaiteresiran za kupit 125icu , jedna mana puno jaca od od starih automobila :D
a da i vidim da si ti vlasnik onoga kontroverznom apn-a sa motorom od e90 i gljivom na karburatoru
Ovako , apn je od mog brata , mito je prodan ali postoji mogucnost da ti sredim ako bi ga kupija , kad sve ispitan javim ti za cijenu , gilera NAŽALOST prodana :(
Prijevozno sredstvo za osobne potrebe , kupljen prije dva miseca u Karlovcu ,2000 god. 10500 tkm . ITALJET DRAGSTER 180 8)
(http://img514.imageshack.us/img514/72/dsc03728ew3.th.jpg) (http://img514.imageshack.us/my.php?image=dsc03728ew3.jpg)
(http://img514.imageshack.us/img514/6510/dsc03731hj1.th.jpg) (http://img514.imageshack.us/my.php?image=dsc03731hj1.jpg)
(http://img514.imageshack.us/img514/6504/dsc03734bp6.th.jpg) (http://img514.imageshack.us/my.php?image=dsc03734bp6.jpg)
tf
Kaj sad na kraju sve imaš ....??
Ljepi motorceki...
pitanje kako ti koci dragster (vozio sam 2) motor ide prejako za ta 2 mala diska unutar felgi , dok mu je ležanje 15 puta bolje nego runneru 180
Bog ekipa , ima san malu prometnu i još nekih problema ali bit cu ja dobro za koji dan :subi: tako nekako .
Cagiva je iz 1991 , mislin da se sad prodaje u ovakvom stanju
(http://img221.imageshack.us/img221/5061/dsc03884wy4.th.jpg) (http://img221.imageshack.us/my.php?image=dsc03884wy4.jpg)
(http://img221.imageshack.us/img221/8725/dsc03885fr0.th.jpg) (http://img221.imageshack.us/my.php?image=dsc03885fr0.jpg)
veky- sad iman samo skuter, ali i on ce još malo u svit
Brat mi sad vozi mizija , pa evo slika
(http://img229.imageshack.us/img229/111/dsc03863ou7.th.jpg) (http://img229.imageshack.us/my.php?image=dsc03863ou7.jpg)
ovi model se proizvodio do 94 . a nakon idu noviji tj. mito evolutio (ducati replica) inace za sve o 125icam možeš na ci na mome forumu
http://www.125cc-club.com/forum
kolika je cijena Mita i korupcije jer me zanima cisto informativno
:D
stari hitno je molin te.....jel prodajes ovoga zelenog CTX-A ili BT-A sta imas na slici....ovoga sta lici na krossera.... molin te ka boga... nadji ga ako si ga izgubia.....prva liga motor...... da bi dusu za njega.... molin te odg.....prejeben......stariii molin e javi mi se na msn-u...!!! [size=24]bestial_deform@hotmail.com[/size]
Znaci MSN mi je bestial_deform@hotmail.com
MOLIN TE rjesi to !!!!
Ovako , to zeleno nije ctx, to je gilera rc 125, nju san ponovo cilu rastavija do vide , sve ispjeskarija bacija šprickit i kupija sve novo do vide
i onda su mi tribale hitno pare i proda san ga prijatelju ispod cjene
i nije mi ža jer je motor na sigurnome i mogu uvik bacit dir, e sad koji
tebe bt zanima , oba dva su prodana, crveni je završija karijeru a za ovoga šta nije gotov ti mogu pogledat , sad ovisi šta tebe zanima koji
motor. Buduci da ja nisam dobar s vrimenom ne mogu ti ništa obecat,
jer san vec reka nekim ljudima da cu im pogledat za aute , ali neman
vrimana ni spavat pa da nebi ispalo da samo nešto baljezgan, ti lipo
vidi šta oceš pa ce mo nešto nac. ;)
stari..... nisan zna da je gilera ali sad kad mi je prijatelj reka ok je..... ali nasa san Betejca odlicno sredjenog..... za male pare...ali vidit cu ocu li jos sta uzimat...imas jos moj mail i moj msn...lako cemo se cut kad uvatis vrimena...btw. kakve aute trazite.....ja i prijatelj mi prodajemo južinu u podu.... odlicno sredjenu, felge od bmw-a ... sportske papucice i volan.... apoteka iznutra ...vanka smo skinili branike...lud je lud... znaci to yugo i ficu u podu malo manje sredjenu...
pa ti si iz trogira.... stari mozda te znan.... vjerovatno.... znas gruju,keka.nidju,komunistu i ekipu.... iz segeta su ali dolaze u tg.... ???
uglavnom vidit cu sta cu jos uzimat pa cu ti javit !!!
Znam ih , ako ti šta bude tribalo od djelova javi , stavi sliku od bt-a
evo san kupija Tomos automatica za 199 kn :haha: :haha:
(http://img180.imageshack.us/img180/3115/35647dsc04277122468lonq8.th.jpg) (http://img180.imageshack.us/my.php?image=35647dsc04277122468lonq8.jpg)
Iman ga u planu samo malo obnovit da me služi za prvu ruku
Jedna nova od brace
(http://img517.imageshack.us/img517/5879/dsc04496mu0.th.jpg) (http://img517.imageshack.us/my.php?image=dsc04496mu0.jpg)
(http://img517.imageshack.us/img517/53/dsc04506qk4.th.jpg) (http://img517.imageshack.us/my.php?image=dsc04506qk4.jpg)
I napokon u pogonu
(http://img179.imageshack.us/img179/11/dsc04504mj8.th.jpg) (http://img179.imageshack.us/my.php?image=dsc04504mj8.jpg)
(http://img179.imageshack.us/img179/4858/dsc04505xo3.th.jpg) (http://img179.imageshack.us/my.php?image=dsc04505xo3.jpg)
(http://img117.imageshack.us/img117/7202/dsc04510yf3.th.jpg) (http://img117.imageshack.us/my.php?image=dsc04510yf3.jpg)
(http://img117.imageshack.us/img117/149/dsc04511iz0.th.jpg) (http://img117.imageshack.us/my.php?image=dsc04511iz0.jpg)
(http://img117.imageshack.us/img117/4869/dsc04512ha1.th.jpg) (http://img117.imageshack.us/my.php?image=dsc04512ha1.jpg)
(http://img178.imageshack.us/img178/3176/dsc04513ur8.th.jpg) (http://img178.imageshack.us/my.php?image=dsc04513ur8.jpg)
