Oldtimeri => Oldtimer garaža => Autor teme: AlfaZD - 27 Srpnja, 2007, 23:29:43
Naslov: AlfaZD / Resto `91 Rover Mini
Autor: AlfaZD - 27 Srpnja, 2007, 23:29:43
Ovo je `91 Mini 1000 ( Rover-ov )
Ovakav je dosao
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn0820.jpg)(http://)
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn0839.jpg)(http://)
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn0827.jpg)(http://)
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn0836.jpg)(http://)
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn0828.jpg)(http://)
slijede radovi....
Autor: AlfaZD - 27 Srpnja, 2007, 23:44:28
kazu da slika vrijedi 1000 rijeci
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn1046.jpg)(http://)
novine ispod tapeta.... kao to je odlicno, "piju"  vodu
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn0861.jpg)(http://)
a ispod novina
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2204.jpg)(http://)
lijeva strana je nesto bolja ( bez novina )
(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2206.jpg)
(http://)
ruzina u portapaku
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2198.jpg)(http://)
Autor: AlfaZD - 27 Srpnja, 2007, 23:55:50
jedna lijepa gnjilada ispod zadnjeg desnog stakla
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn0834.jpg)(http://)
rezanje do zdravog
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2219.jpg)(http://)
prvo unutrasnji lim
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2231.jpg)(http://)
pa vanjski lim
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2252.jpg)(http://)
Autor: AlfaZD - 28 Srpnja, 2007, 00:05:30
slijedeca gnjilada je ( bila ) ispod prednje sajbe....
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn0843.jpg)(http://)
kad je skinuta sajba pokazalo se
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2193.jpg)(http://)
zahvatilo je i unutrasni lim
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2199.jpg)(http://)
rezanje do zdravog, nepristupacno je za brusilicu, pa je u akciji plasma cutter
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2202.jpg)(http://)
unutrasnji lim
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2229.jpg)(http://)
i vanjski lim
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2256.jpg)(http://)
ima jos raditi, puuuuno, puuuuno....
Autor: Renegade - 28 Srpnja, 2007, 00:43:18
Autor: AlfaZD - 28 Srpnja, 2007, 00:44:45
i danas, i danas !    :jak:
Autor: pitam se pitam - 28 Srpnja, 2007, 01:06:26
kak je ovaj TRUL...pa tak ni yugo iz 91 nije :P  :P
Autor: kile - 28 Srpnja, 2007, 09:21:24
Lijepo radiš AlfaZD.  :palac:
cekam nove slike.   :)
Autor: Jaki - 28 Srpnja, 2007, 12:08:19
ima posla... ali neka neka... lijepo to tebi ide. samo ti ja predlazem
da se prvo uhvatis onih najgorih mjesta... pa onda kada to uredis
kreni prema ovim sitnim trulezima.
Autor: turBina - 28 Srpnja, 2007, 12:31:44
Citat: pitam se pitam
Da stvarno za '91! Pa šta minici imaju tak lošu zaštitu lima??
Autor: Bane_Mini - 28 Srpnja, 2007, 22:12:06
svi mini morrisi koji se sklapaju od 80e godine imaju skoljke koje se sklapaju u belgiji i koje realno nisu ni za k... to ispod soferke je standard... ovaj je bas bio zapusten... jbt moja skoljka koja se sad radi je 8 godina stajala na njivi i nije toliko trula, doduse ona je 75. godiste...
srecno u radovima
Autor: AlfaZD - 28 Srpnja, 2007, 23:34:01
ovaj Mini nema niti punih 69 tkm, ali je svo vrijeme zivio na ulici, bez ikakve paznje. u stvari, najvise je - stajao.  rezultat se vidi.
sve ce se to napraviti.
2 Jaki - prvo rjesavam gornji dio, krov - stupovi - do ispod stakala. zatim se skidaju oba mosta, ( kod hvatista zadnjeg mosta ima trulezi ) gola  skoljka ide na kariolu, na visinu 30 do  70 cm.
 to je zgodna visina za raditi, a i pokretno je.
Autor: ST-w115-ST - 29 Srpnja, 2007, 01:24:23
bravo majstore lipo ti to radiš. ;)
Autor: kowalski - 29 Srpnja, 2007, 04:10:18
Citat: Bane_Mini
netocno.tj.,djelomicno tocno.samo su se neki sklapali u Belgiji-ne svi,i ti su u pravilu lošiji,zato što je promjenjen postupak cincanja školjki...druga stvar,ovo je roverov mini-imam jednog takvog doma,tako da limarija nije uopce zapanjujuce loša-cak dapace,to je standard za to godište.
vidio sam ja '94. kojem je bez problema kroz pragove u auto mogla uskocit macka.
Autor: Bane_Mini - 29 Srpnja, 2007, 15:18:58
da.. neki su sklapani u belgiji i ima onih koji su sklapani u engleskoj... ali svi imaju belgijske karoserije
Autor: mean Mini - 30 Srpnja, 2007, 10:47:25
Bas je zapusten >:(
Autor: Tookie - 03 Kolovoza, 2007, 12:25:08
stvarno je zapusten i koma ali drago mi je kada vidim da je u rukama covjeka koji ce ga srediti... :palac:
Autor: AlfaZD - 08 Kolovoza, 2007, 21:15:03
uspio sam odvojiti nesto vremena za Minija
skinut je zadnji most, ( sad se tek vidi  pravo stanje mosta ), oguljen zadnji donji vezni.... ciscenje ruzine
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2530.jpg)(http://)
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2531.jpg)(http://)
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2532.jpg)(http://)
hvatista uopce i nisu losa, ima uz njih na obje strane rupa u djep pored zadnjeg sica, nista strasno
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2533.jpg)(http://)
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2537.jpg)(http://)
ali zato je sam zadnji most dosta los.... zasad je samo opran, bio je pun blata, bice jasnije sutra kad se osusi
(http://)(http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2545.jpg)(http://)
Mini  je sio na kariolu, radovi se mogu nastaviti.... cim opet bude malo slobodnog vremena... a dotle je ipak pokretan, najgore je kad auto lezi ka  kaseta, nemozes ga maknuti, a lako zasmeta
Autor: AlfaZD - 19 Kolovoza, 2007, 00:14:50
(http://[img]http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2682.jpg)[/img]
Autor: Brutalac - 19 Kolovoza, 2007, 02:34:42
Od kuda nabavljas dijelove limarije?
Autor: Bane_Mini - 19 Kolovoza, 2007, 09:19:25
vlatko sta god ti treba od delova limarije javi mi...
Autor: Brutalac - 19 Kolovoza, 2007, 13:43:46
Ma nije da mi treba nego samo pitam od kuda nabavlja  :D
Autor: AlfaZD - 19 Kolovoza, 2007, 14:11:49
nakon sto su me domaci ducani i uvoznici   totalno izvarali s obecanjima, rokovima isporuke,
( a vadili su kataloge Klokenheim-a i sl. moralo bi da mogu nabaviti po narudzbi )
rijesio sam drugacije.... http://www.minimagic.eu/   u Belgiji. najveci problem ostaje transport, ali i to se rijesi.    :D
Autor: Bane_Mini - 19 Kolovoza, 2007, 18:20:23
a kako radis placanje i jel salju delove za beograd???
Autor: AlfaZD - 19 Kolovoza, 2007, 21:57:52
ovo je za sad bio prvi put, placeno je cash, i prijateljica mi je to donijela sa sobom, usput.
mislim da  se moze kupiti i preko neta, platiti karticom, ( za sad nisam probao ), a da li bi slali van EU, to bi ih prvo trebalo pitati.... jer neki ne zele ni na mail odgovoriti, kad vide odakle dolazi.
Autor: pitam se pitam - 19 Kolovoza, 2007, 22:08:16
znaci tako izgleda mini bigfoot :P  :jak:  8)
Autor: Brutalac - 20 Kolovoza, 2007, 02:04:35
Ne nego ovako  :P
(http://www.miniclubzagreb.hr/fotke/Imm-2006-rf-084.jpg)
Autor: pitam se pitam - 20 Kolovoza, 2007, 02:20:59
idesh :D ...mini karoserija na sasiji od uaza :-o  :-o  8)
Autor: Brutalac - 20 Kolovoza, 2007, 03:26:19
U danskoj su bila dva takva... :D
Autor: AlfaZD - 11 Rujna, 2007, 22:05:16
radovi se nastavljaju, kad god uhvatim malo vremena.... mali update
ruzina otkinuta, ostala je rupetina
(http://[img]http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2891.jpg)[/img]
(http://[img]http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2890.jpg)[/img]
poluproizvod - buduci novi dio
(http://[img]http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2892.jpg)[/img]
zavareno.... ( sjetim se onog vica kad su Skot i sin isli u Australiju.... tata, tata koliko jos ?  ima jos, sine... malo kasnije: tata, tata, koliko jos ? suti sine, i plivaj )
(http://[img]http://i153.photobucket.com/albums/s222/AlfaZD1/Rover%20Mini/dscn2893.jpg)[/img]
Autor: kowalski - 12 Rujna, 2007, 12:17:04
sad gledam slike..most je dosta loš,ali se da sanirati još...ali obavezno ga pojacati sa obje strane (i dolje i gore),inace ce se slomiti nakon par mjeseci...jesu ti matice od mosta popucale?one što su uprešane u karoseriju?
Autor: AlfaZD - 12 Rujna, 2007, 22:43:41
nisu popucale, lipo se odvidalo,  ruzina ih nije dohvatila.
a sam most je los, najradje bih kupio novi, (ili dobar rabljeni)  samo jos nisam otkrio odakle i kako.
za pocetak cu s ovog sve poskidati, i  ispjeskariti ga, pa cu odluciti da li ima smisla krpati ga.
Autor: kowalski - 13 Rujna, 2007, 12:50:04
hm...a ovo?
http://www.minispares.com/Product.aspx?pid=38280
Autor: AlfaZD - 14 Rujna, 2007, 00:22:06
da, odlicno, jedino treba provjeriti troskove dostave.
Autor: Brutalac - 14 Rujna, 2007, 01:30:53
Citat: AlfaZD
...provjeriti troskove dostave.
PUN KUJAC!!!
Veliko je i tesko tak da ce kostat >:(
Autor: kowalski - 14 Rujna, 2007, 12:28:11
a onda nek se decki iz kluba ponude...zar nije bila prica da netko ima most viška?
Autor: Brutalac - 14 Rujna, 2007, 12:30:01
Mostova nikad viska  :P
Autor: AlfaZD - 14 Rujna, 2007, 22:55:51
Citat: Mini Vlatko
Citat: AlfaZD
PUN KUJAC!!!
toga me i je strah. ali, polako.... ako se bude moralo, nabaviti cu ga nekako.
