Autor Tema: Jeep CJ7 Diesel Automatik 1970, 158ks  (Posjeta: 18952 )
Offline Miro Spiro
  • Postova: 32
  • Vozilo:: Talbot Simca 1000, Toyota Tercel 4X4
« Odgovori #30 : 30 Siječnja, 2012, 23:28:08 »
Production         1976-1986
Engine
150 cu in (2.5 L) AMC I4
151 cu in (2.5 L) GM Iron Duke I4
232 cu in (3.8 L) AMC I6
258 cu in (4.2 L) AMC I6
304 cu in (5.0 L) AMC V8
145 cu in (2.4 L) Isuzu Diesel C240
Transmission
5-speed manual
4-speed manual
3-speed automatic />3-speed manual
Wheelbase
93.3 in (2,370 mm)
Length  148 in (3,759 mm)
Width   68.5 in (1,740 mm)
Height  67.7 in (1,720 mm)
Curb weight
2,707 lb (1,228 kg)[25] Production         1976-1986
Engine
Transmission
5-speed manual
4-speed manual
Wheelbase
93.3 in (2,370 mm)
Curb weight
Jeep History Book
"The first Jeep CJ7was introduce in 1976 and 379,299 were built during 11 years of production. It was the upgrade of CJ5. The new CJ was much more suitable for “civilian” use than its predecessors."
Between 1980 and 1982 a diesel-powered version had been manufacturing in the Ohio factory and for export only".
« Zadnja izmjena: 30 Siječnja, 2012, 23:37:09 Miro Spiro »
Offline Renegade
« Odgovori #31 : 30 Siječnja, 2012, 23:33:39 »
Citat: wr2411;287462
Proizvodio se i prije 1976  ali evo vidjet ćeš glupo je i nepotrebno sada  ići u rasprave.
Nije se proizvodio. Upisi mi ovdje broj sasije i reci cu ti gdje je taj tvoj proizveden. Onaj broj sto je u osiguranju je nedovoljan.
Citat:
Vozilo s registarskom oznakom ZG2411FI, marka JEEP, CJ 7,, šasija 7009893 je na dan xxx bilo osigurano kod osiguravajućeg društva: ALLIANZ ZAGREB D.D.
Broj police od automobilske odgovornosti: 0401164297
Offline YUREEK
  • Postova: 1277
  • Thanked: 3 times
  • Lokacija: Međimurje
  • Vozilo:: Zastava 750 - 1970
« Odgovori #32 : 31 Siječnja, 2012, 01:20:12 »
Citat: wr2411;287343
Haha hvala nemam ja taj Jaguar nego bivši vlasnik ovog auta, a inače taj je Jaguar stvarno u odličnom stanju.
Ako je bijeli Jeep Wrangler sa diesel motorom Land Rover onda je to moj bivši auto.
hm, kratko pitanje : bijeli jeep ?? podignut, ko iz dućana . . . dva krova . . .automatic . . . . pa prodan negdje 2003/4 prema Zaprešiću? jeste li Vi možda stanovali kod Doma športova ?
Lefko ga najdeš, kak raj je lepi, med Murom i Dravom tam ti leži, de čuješ ftičju najlepšu popevku  - Međimurje to je - tu doma buš ti .
Offline kalkan
« Odgovori #33 : 31 Siječnja, 2012, 03:53:26 »
Lijep i atraktivan Jeep.
Da je bilo koji drugi forum u pitanju, rekao bih da je auto patka. CJ7 iz '70 sa BMW V6 motorom...
Moze li koja slika motora? Naime, ako je motor 525TDS, odnosno M51D25 sa intercoolerom, motor ima 143ks/280nM max. Jedino ako je noviji 525d, odnosno M57D25 sa 166ks/350nM. Nema trece opcije.
« Zadnja izmjena: 31 Siječnja, 2012, 04:13:34 kalkan »
Offline Renegade
« Odgovori #34 : 31 Siječnja, 2012, 10:20:38 »
Citat: wr2411;287364
Da motor je V6 - BMW 525 TDS 2.5 158ks.
Citat: kalkan;287490
Kolega Kalkane! Citaj sve! Koji je BMW dizel - V6????????
« Zadnja izmjena: 31 Siječnja, 2012, 10:23:32 Renegade »
« Odgovori #35 : 31 Siječnja, 2012, 11:45:19 »
Nista daj sliku motornog prostora pa cemo odgonetnuti.
Offline wecomakina
« Odgovori #36 : 31 Siječnja, 2012, 11:55:41 »
Ako se ne varam za volanom ove grdosije cesto znam vidjat mladju zensku osobu ili je ipak rijec o zutom :D,sve u svemu kad god ih vidim izmame mi osmijeh!!
Offline wr2411
  • Postova: 40
« Odgovori #37 : 31 Siječnja, 2012, 16:57:13 »
Citat: JURICA;287486
Moj je bio sličan opisu ali nije  bio automatic.
Offline wr2411
  • Postova: 40
« Odgovori #38 : 31 Siječnja, 2012, 16:58:50 »
Citat: Žein;287555
Budem stavio sliku motora.
Offline wr2411
  • Postova: 40
« Odgovori #39 : 31 Siječnja, 2012, 17:04:11 »
Citat: wecomakina;287557
Haha ne znam za prije, zadnjih par godina ga ja vozim.
Offline chbr2a
  • Postova: 801
« Odgovori #40 : 02 Veljače, 2012, 00:07:50 »
ma zicer onaj žuti što dođe u ozalj :) mrcinaaa.
a glete, čovjek ima svoju viziju vozila i njegova vizija i ideja vozila je ta da želi unutra motor od bemveja i da ga želi voziti svaki dan a ne gledat kako stoji i taljigat se u nekom puntu zato što mu je žao ovoga ....
ima auto za eksploataciju i za to mu služi a vi se opasno okomili na čovjeka što je napisao jedno viška V ili se krivo izrazio ,...
dobar je, želim krug B-)
"everything is restorable"
« Odgovori #41 : 02 Veljače, 2012, 07:59:50 »
Auto je super ali mi nije jasno kako automatik. Vjerovatno se ciljalo na gradsku vožnju i šminku, jer ako upaneš u blato automatikom je zabranjeno ljuljanje auta naprid nazad
Offline wr2411
  • Postova: 40
« Odgovori #42 : 02 Veljače, 2012, 09:55:06 »
Citat: chbr2a;288361
Sve si dobro napisao pa radim si taj auto za svaki dan, a ne da gledam u novčanik svaki put kada napravim par kilometara.
Offline wr2411
  • Postova: 40
« Odgovori #43 : 02 Veljače, 2012, 09:56:33 »
Citat: igor136;288391
Da ciljalo se za gradsku vožnju jer on više nije za terene zbog starosti, a ova getriba koja je u njemu ima više programa rada (sport i economic)
Offline wecomakina
« Odgovori #44 : 02 Veljače, 2012, 10:16:09 »
Ma brate radi kako ti se prohtije ako oces od fice motor nagurat unutra ti ga stavi ima puno ljudi koji pate samo na originalnost ne razmisljajuci da su ljudi razliciti i da neke zaboli uvo oce taj auto sutra vrijediti milijune ili nece jer je sic od telece,a ne konjske koze...sve u svemu jeep je grdosija samo takva i uzivaj svaki tren u njemu i zajebi sve koji oce tip top origigi i samo origigi,nedaj boze da se ja docepam takvih autica bio bi mokar koliko bi me ljudi popljuvali zasto si ovo,zasto si ono,pa to neide tako,gle katalog sta pise,visina ne valja...jel pali?!pali...e pa onda nema rasprave tvoj auto,tvoj gust i udri misko brigu na veselje!!!
