http://www.thevolvoforums.com/volvo-740/2406-89-740-gl-fuel-tank.htmlIt mounts just behind the rear passenger seat in the boot / trunk. It
connects up to the main talk via an L shaped rubber hose under the car, thus
acting as one large 82 litre tanks, no switching of tanks required. This
rubber hose is prone to cracking and causing fuel leak, and needs to be
replaced every 5 - 7 years but it's only $10 - $15. Since the auxiliary
tank sits higher than the main tank, it is only filled when the fuel
quantity exceeds 60 litres. Your trunk floor already has an opening pre-cut
for the installation, which is covered up by a hatch for models without the
auxiliary tank. It has its own fuel sender which is wired in series with
the main tank sender. Your fuel gauge is already designed to read from both
tanks, all you need to do is to remove a screw for Yazaki or clip for VDO on
the back of the fuel gauge to change the reading from 60 litres to 82
litres.
The auxiliary fuel tank option seems quite rare in the States, I have only
seen ONE 700 series on eBay US with the auxiliary fuel tank, and it was a
Turbodiesel. You do loose a little bit of your trunk space but depending on
what type of driving you do, you might find it a worthwhile trade-off to
carry extra fuel. The moulded carpet lining in the trunk is also shaped
differently to cover the auxiliary fuel tank. If you're really keen on the
conversion and you couldn't find any parts in the States, I can send the
parts to you from Australia if you don't mind the shipping cost. Since
they're standard equipment for the Australian market it's very easy to find
them here.
