to ivan ... da... bas imam 1000 kn puta 8 za klipove.
Brand: Keith Black/KB Pistons
Product Line: Keith Black Hypereutectic Pistons
Part Type: Pistons
Part Number: UEM-KB156-030
Bore (in): 4.030 in.
Bore (mm): 102.362mm
Piston Style: Flat top, with two valve reliefs
Piston Material: Hypereutectic aluminum
Compression Distance (in): 1.678 in.
Piston Head Volume (cc): +7.00cc
Wrist Pin Style: Press-fit or floating
Pin Diameter (in): 0.927 in.
Piston Ring Thickness: 5/64 in. x 5/64 in. x 3/16 in.
Quantity: Sold as a set of 8.
Notes: Piston gram weight 569g, pin gram weight 145g.
Price: $246.69
ili
Brand: Federal Mogul
Product Line: Federal Mogul Cast Pistons
Part Type: Pistons
Part Number: STL-310NP40
Bore (in): 4.040 in.
Bore (mm): 102.616mm
Piston Style: Flat top, with four valve reliefs
Piston Material: Cast aluminum
Compression Distance (in): 1.654 in.
Pin Diameter (in): 0.928 in.
Quantity: Sold individually.
Price: $18.99
To je daleko jeftinije od 1000kn/kom. Istina da to nisu baš
neki super kvalitetni klipovi, i ja ih u svom motoru sigurno ne bih
imao, ali da su bolji od 30 godina starih klipova koji su stajali
zapeèeni zadnjih xy godina, sigurno jesu.
