Autor Tema: POMOĆ golf 2 1.99 tdi,sa alfinim varijabilnim turbom  (Posjeta: 4565 )
Offline BORAC ISTRA
pozdrav.
zanima me dali jre ko imao sikustva s motorom 1.9 tdi u golf 1/2/3  na pumpu od dailya ili crome znači bez struje i da je pritom ugradio varijabilni alfin turbo,i ako ko da koja je bila prerada?i kemija i ča se sve mora napravit/nabavit?dosta mi je bitan točan podatak jer krećem u avanturu :=) lp
Quote:
Originally Posted by deda
Offline ledeni09
« Odgovori #1 : 13 Rujna, 2012, 14:35:55 »
Dobar poduhvat sretno i javljaj kako napredujes,sto se tice tvog pitanja to ce ti bit vise korisni strani forumi.
Offline vwfan
  • Postova: 31
« Odgovori #2 : 13 Rujna, 2012, 17:41:47 »
Nedavno me neki lik iz Poreča zvao u vezi nekog oglasa i u keca slaže nešto slično kao i ti , uglavnom ima otpad pa ga probaj kontaktirat.
Offline ledeni09
« Odgovori #3 : 13 Rujna, 2012, 18:17:07 »
http://i690.photobucket.com/albums/vv265/dweezel17/yeomansenginenstuff016.jpg
http://i690.photobucket.com/albums/vv265/dweezel17/yeomansenginenstuff026.jpg
http://i690.photobucket.com/albums/vv265/dweezel17/yeomansenginenstuff019.jpg
http://i690.photobucket.com/albums/vv265/dweezel17/yeomansenginenstuff025.jpg
http://i690.photobucket.com/albums/vv265/dweezel17/yeomansenginenstuff021.jpg
Malo opširnije o karakteristikama
The  compression ratio is 14-14.5:1 can't remember exactly.Still using  79.5mm bore with a little more pistion to cylinder clearance.We need to  keep the block as rigid as possible with such high cylinder pressure.
Cunningham  rods,diamond pistons,total seal rings,comp cams valve springs,valves  form techtonics tuning reworked to be setup with solid lifters,Fass  electric fuel pump. A-pump form 4bt cummins with 10mm plungers and maxed  out fueling (250cc's).Cummins nozzles 5x.017" (I think),Turbo's are  from 4 and 6 cyl hino engines.Kind of proud to say that both turbo's and  exh manifold are ebay stuff .Probably have $300-400 into the turbo's  and manifold.
Still has stock cam and crank.probably could use a  better cam but aparently a hydraulic cam would'nt be correct to use with  solid lifters even though I'm using a the stock cam which was made for  hydraulic.I'm confused about the difference between solid lifter cam's  and hydraulic cam's ??
Last years dyno with different turbo's made 345 whp @ approx 4100rpm.I think we should be 400-450 bhp this time around
Evo nesto znam da ne pomaze al da se vidi...
« Odgovori #4 : 13 Rujna, 2012, 20:28:09 »
Vaaaaauuuuuu... :sok:  :sok:
Ovu makinu je vec netko stavljao na forum.. netko od ''stare oldschool garde''... Ili The Big... Ili netko. Definitivno - bolesna prerada legendarnog ''golfa dizla''.
Sto se tice turbine/pumpe od Crome ja mogu samo reci da je standardni 2,5 TD Cromin (ili Lancijin) motor - zvijercina upravo radi te turbine. Nedavno ju je Laniva prodavao za bagatelu. Kad je ''zdrava'' i kad nema lufta - ''puse i puni'' doslovce ko blesava. Ja sam pak na Cromi imao pumpu, turbinu i brizgalice (dizne) od Iveca Turbodailya i mogu reci da je tek onda auto bio cista bolest. Karoseriju od tonu i cetristo doslovce zafijuce ko metak do krajnje brzine od 180km/h kad te doslovce ''pljune'' iz sjedala jer je pumpa bila mehanicki blokirana na kojih 3500okretaja.
Tako da... Ta turbina na Golfovom motoru mora ''cuda raditi''.
Nazalost, po svemu sudeci... Jedini ti je spas da pronjuskas po fau ve forumima, bilo kod nas, bilo ''vani'' pa da vidis ako ima koji ''pacijent'' da je radio nesto slicno.
Ili.. :D Stisni zube i budi pionir. Bar ti imas iskustva sa sarafljenjem i nisi ''zelen'' sto se tice prljavih ruku, alata i garaze. Sretno u svakom slucaju... Ako ća bude - daj nas izvjesti. :palac:
Pitanje je samo... :rofl: :rofl: :rofl: Imas li veze na tehnickom...? Kako ces to registrirati...? :rofl: :rofl:
Offline ledeni09
« Odgovori #5 : 13 Rujna, 2012, 22:52:50 »
Ne znam za nekog od drugih da je stavljo te slike i opis po forumu ili bilo gdje prvo sam stavio na qm forum pa sad tu :ghh::ghh:
RACE
« Odgovori #6 : 18 Rujna, 2012, 10:02:04 »
A zasto ne std pumpa od TDi-a? Gdje je problem? Spojiti kompjuter i instalaciju ?
Sto se varijabilnih turbina tice, svaka se da napraviti da ima ili tlacnu ili vakumsku regulaciju.
1.9 TDi da bi stvarno jurio  treba  GT2056 ili GT2256 a najbolja je GT2260.
Offline ledeni09
« Odgovori #7 : 18 Rujna, 2012, 18:19:34 »
I ja se slažem sa tobom da je std pumpa najbolja,jer doslovno moze nalivat u cilindre goriva struja nije problem bar nebi trebao biti.A sad ako netko hoce radit drukcije nesto ja ga podrzavam al kao i sto sam vidio nije ni to neki veci problem....Hm sto se tice turba trebalo bi vidjet sta hoce sa motorom za neki sr ili za svaki dan...
Offline Lugburz
  • Postova: 1817
  • Vozilo:: Octavia 1 1.6 lpg
« Odgovori #8 : 18 Rujna, 2012, 18:21:50 »
sta je ovo je**te,veca bosch-pumpa od masine:sok:
Offline ledeni09
« Odgovori #9 : 18 Rujna, 2012, 21:45:20 »
Hehe vidis,al još da vidis rezultat sa valjaka jbt!
Offline Lugburz
  • Postova: 1817
« Odgovori #10 : 18 Rujna, 2012, 23:07:02 »
jel ovo ima na krovu sedlo i vuce slepu?
RACE
« Odgovori #11 : 19 Rujna, 2012, 23:52:46 »
Citat: ledeni09;341237
Ja sam i spomenuo one turbine za auto za svaki dan. A, ....... moze i SR.
RACE
« Odgovori #12 : 19 Rujna, 2012, 23:53:29 »
Dupli, ...........brisi.
Offline shegy
  • Postova: 23
« Odgovori #13 : 05 Listopada, 2012, 15:36:36 »
da neotvaram novu temu,
kako u praksi funkcionira TDi sa mehaničkom pumpom od običnog TDa , naravno malo otvorena
Offline ledeni09
« Odgovori #14 : 05 Listopada, 2012, 22:16:39 »
Nista posebno kao običan td se ponasa..
