Autor Tema: Megatronov odjel  (Posjeta: 5510 )
Offline Megatron
  • Postova: 440
  • Thanked: 17 times
  • Lokacija: Kvarner
  • Vozilo:: Olupina
Megatronov odjel
« : 18 Srpnja, 2019, 03:14:53 »
Nekima već poznat projekt, ali da ponovimo koji prvi put otvaraju.
Fiat 500L iz 1969. godine, kupljen u Italiji u proljeće 2019., pokrajna Toskana u jednom malom mjestu Monticiano blizu grada Siene. Imao je crne SI registracijske pločice. Zadnji put je registriran 1999. godine i od te godine stoji na jednom privatnom zapuštenom posjedu u šumi i šikari punih 20 godina do 2019. u proljeće kada ga kupujem i prebacujem u RH u Kvarner.
https://ibb.co/8Xckffh
https://ibb.co/MS4Js6G
https://ibb.co/LJxj1mw
https://ibb.co/KyjxnsG
https://ibb.co/G5pHQQH
https://ibb.co/pfKP4Cr
https://ibb.co/kmxmmxt
https://ibb.co/wMpphBk
https://ibb.co/fkrPmgX
https://ibb.co/mStH8Ng
https://ibb.co/x3C6pCw
https://ibb.co/vLmyJtB
https://ibb.co/3kbPV24
https://ibb.co/XktH9SZ
https://ibb.co/qj08q3M
U ljeto 2019. rastavljen do zadnjeg šarafića osim vrata i prednje haube. Razlog ostavljanja vrata, mislim da bih ga trebao prethodno staviti na limarski stol i vratiti u centar jer je dobio udarac po lijevom blatobranu i lijevom A stupu koji se malo pomaknuo i zazori lijevih vrata se ne poklapaju po rubu B stupa, gornji čošak lijevih vrata malo grebe po B stupu, a vrata nisu obješena i panti nemaju zazora.
https://ibb.co/t4zPhL2
https://ibb.co/3zM6fz8
https://ibb.co/bPgXcXT
https://ibb.co/9bh5Fqb
https://ibb.co/txgZ6x8
https://ibb.co/VYcKr9n
https://ibb.co/9s56m8j
https://ibb.co/Zmcgbf7
https://ibb.co/K2fmqL3
https://ibb.co/bsHKkBZ
https://ibb.co/rxydB9r
https://ibb.co/8947F3z
https://ibb.co/QHfCVs2
https://ibb.co/mb0Kd98
https://ibb.co/tcZFh5D
https://ibb.co/DKv4gKt
https://ibb.co/gwfsX6B
https://ibb.co/zSDKsZJ
https://ibb.co/4PBSs8w
https://ibb.co/6RvZRwf
https://ibb.co/QDM48zq
https://ibb.co/TTtrgbK
https://ibb.co/MGvtY6f
https://ibb.co/y4Hhmrw
https://ibb.co/2PRQngF
https://ibb.co/JcL44DJ
https://ibb.co/XY1mNH4
https://ibb.co/wRrpL83
https://ibb.co/SQh4R9N
Jedno 50% limarije moram zamijeniti novom;
-prednji lijevi blatobran
-lijevi A stup
-donji glavni pod
-vanjski i unutarnji pragovi
-stražnje vatropregradne ploče između kabine i motora
-stražnja lijeva šalica amortizera
-traverza što povezuje stražnje šalice amortizera ne nudi se kao rezervni dio, treba je fabricirati po kalupu
-donji dio ruba lijevih i desnih vrata kao rezervni dio
-donji dio ruba stražnjeg stakla kao rezervni dio
-žljeb stražnjeg stakla kedera
-prednja podnica prtljažnika
-prednji šus pleh
Za stražnje blatobrane još ne znam dok se kompletna karoserija ne ispjeskari i ne vidi stvarno stanje, možda idu samo rubovi blatobrana novi, a možda kompletni stražnji blatobrani.
« Zadnja izmjena: 30 Svibnja, 2021, 21:21:31 Megatron »
Odg: Megatronov odjel
« Odgovori #1 : 18 Srpnja, 2019, 07:53:53 »
stari moj ..imaš jaja...jako loša limarija..
« Odgovori #2 : 18 Srpnja, 2019, 08:17:14 »
Uf. Pitanje je šta će ostat na okupu iza pjeskarenja. Znan da se sve može u životu, ali ovo će bit "veselo".
Svaka čast na hrabrosti.
Sent from my Armor_X using Tapatalk
« Odgovori #3 : 18 Srpnja, 2019, 09:02:05 »
Nije mi se dalo klikat link po link na sliku al za ovo malo kaj sam otvorio - fiuuuuuu! :shok:
Želim ti puno sreće i strpljenja! Ako izdržiš imat ćeš lijep autić, ove pune felge i male lampe su meni nenadjebiv detalj na njemu. Prava boja da se vidi/do izražaja dođe krom i pogodak! Naravno, u mojim očima.
Još jednom - sretno!
Offline trajkeša
« Odgovori #4 : 18 Srpnja, 2019, 11:45:13 »
Bojim se da će ga pijesak popapati i ovo malo što ga je ostalo  :unsure2:
« Odgovori #5 : 18 Srpnja, 2019, 13:42:11 »
Zanimljiv i hrabar projekt!!  Zanima me kako ce to na kraju izgledat, vjerojatno ko iz ducana!!!  Takav malisa bi mi bio ukras u vrtu, u ovakvom stanju , ne bi mi ga se dalo dalje dirat, previse posla za mene!!! Ako sam radis i znas i nije neki posel, ide to onda polako i jeftino, ja bi sve trebao dati da se radi pa ne bi ni zapoceo takav projekt!! :big_boss:
Offline studentt
« Odgovori #6 : 18 Srpnja, 2019, 14:22:56 »
Auuuuuu
Da mi ga tko daje dzaba nebi ga uzeo.
Svaka cast na projektu
Pratim  :good:
Offline Megatron
  • Postova: 440
  • Thanked: 17 times
  • Lokacija: Kvarner
  • Vozilo:: Olupina
« Odgovori #7 : 18 Srpnja, 2019, 15:21:44 »
@Amigaboy je radio puno teže kategorije u puno gorem stanju što sam pratio, tako da ovo je negdje gornja srednja kategorija.
Teška kategorija je kada je doslovce svaki dio porozan kao da ga je netko sačmaricom gađao i prošli geleri granate kroz lim.
Ne mogu sada ništa raditi po limu usred sezone jer bi me susjedi zatukli pošto sam okružen iznajmljivačima apartmana, tako da paljenje flekserice do 15.9. ili bolje 1.10. ne dolazi u obzir.
Sad radim tihe poslove, pa sam rastavio kompletnu getribu u sastavne dijelove pošto je moja getriba nesinkronizirana i slaže se u sinkroniziranu, pa moram nabaviti  zupčanike sa bočnim konusom za dosjed sinkronih prstenova i drugačijim bočnim kandžama i drugačiji kandžasti rukavci i glavčine rukavaca idu u koje se uključuju brzine. Moj 500L nije dolazio sa sinkroniziranim mjenjačem, tek posljednje serije 500R i to uz doplatu od '72. koji su se proizvodili paralelno sa Peglicom koja se pojavila '72. , a Peglice su sve imale sinkronizirane mjenjače.
Netko će reći da što ne stavim mjenjač od Peglice, ali opet moram rastaviti getribu i prebaciti poluosovine jer su na Peglici poluosovine dulje pošto ima širi stražnji trap i zvono getribe je drugačije, na 500 anlaser stoji s gornje strane, na 126 bočno desno. Zupčanike i dijelove getribe ću nabavljati iz Poljske, pošto nisu skupi.
I moram promijeniti glavni prijenosnik redukcije u getribi, kod mene je 8x41, a Peglica ima 8x39 pa ću biti malo brži. Budem vidio sa frendom iz ulice u ZG, on vozi utrke sa Peglicom, pa možda on uzme ovaj moj par 8x41 koji je jači, ali sporiji, a on meni da svoj par konusnih zupčanika 8x39 koji je slabiji, ali brži.
« Zadnja izmjena: 18 Srpnja, 2019, 15:47:06 Megatron »
« Odgovori #8 : 18 Srpnja, 2019, 17:10:22 »
Zanimljiv projekt. Sritno!  :drinks:
Offline boresky
  • Postova: 1320
  • Thanked: 29 times
  • Lokacija: Križevci
  • Vozilo:: | SAAB 900 1981 |
« Odgovori #9 : 19 Srpnja, 2019, 00:08:22 »
Sretno, becar!! Sve se moze!
Offline Soksi
« Odgovori #10 : 22 Srpnja, 2019, 21:22:21 »
Svaka čast, nadam se da je dobiven na poklon.
« Odgovori #11 : 22 Srpnja, 2019, 21:34:29 »
Nije koliko znamo.. Placen je i on i prevoz iz itali
Offline Ivek
« Odgovori #12 : 22 Rujna, 2019, 07:47:01 »
E ovo se zove projekt, i to je gušt slagati
Pogotovo ako radiš sam i znaš koji ti je cilj.
Poslano sa mog F8331 koristeći Tapatalk
Offline Megatron
  • Postova: 440
  • Thanked: 17 times
  • Lokacija: Kvarner
  • Vozilo:: Olupina
« Odgovori #13 : 22 Rujna, 2019, 17:58:04 »
Sam ću sve raditi, osim PDR izvlačenja jamica od tuče i ostale udubine od nepažnje, to prepuštam PDR umjetnicima, lakiranje i pripremu lakiranja također prepuštam majstorima.
Pjeskarenje još razmišljam isplati li mi se kupiti neki rabljeni jaki kompresor sa velikim protokom zraka ili platiti da se ispijeskari što nije baš jeftino jer morat ću 2 puta voziti na pjeskarenje. Drugo pjeskarenje ide kada skinem prednji vezni lim prednje i stražnje blatobrane obično je tu sve na krakovima šasije i kosturu trulež, a ne može se doći sa pištoljem dok se to ne skine.
Prije bilo kakvog pjeskarenja treba raspunktirati točkaste zavare i eliminirati limariju koja ionako ide na otpad pošto je porozna da se bez veze ne pjeskare površine koje će se ionako škartirati.
Imam neki kompresor kupljen davno od 180 litara sa namontiranim kamionskim kompresorom, ručna izrada, ali to je sve preslabo. :download:
« Odgovori #14 : 22 Rujna, 2019, 18:59:11 »
Daj ga nekome na suhi led pa nebus dva morao voziti. Na klasican način se bu raspao kod truleži!
