Autor Tema: FIcO '80  (Posjeta: 29525 )
Brutalac
FI
« Odgovori #30 : 05 Prosinca, 2006, 00:19:32 »
New windows had to be made to fit smaller apertures. That's easy for the side windows, as they are flat. But how do you make those curved front and rear windows? You make a mould from a strip of metal, 2cm wide and 3mm thick, that exactly represent the outer face of the window. You reinforce it with a frame, so it doesn't wrap when you put it in the oven. Then it's a question of making a cardboard template and two glass sheets are cut to shape. Put one sheet on to the mould, put it in the oven and the glass will drop down into the mould. Then put a plastic sheet on on followed by the second glass sheet. Then it's back in the oven once more and, hey presto, one freshly baked laminated windscreen. The recipe for the rear window exactly the same.
Evo decki...ja se u to fakat ne kuzim tak da ne znam kak to tocno ide ali ak neko kuzi nek se posluzi...rima a :haha:
Bilo bi ok da onaj ko to prevede stavi to negdje na forum di bi moglo posluziti svima kojima treba!
Brutalac
FI
« Odgovori #31 : 05 Prosinca, 2006, 00:23:05 »
He...malo kasnis...natipko ja :P
Tuco
FI
« Odgovori #32 : 05 Prosinca, 2006, 00:29:56 »
Vlatko pa ti si strašan! :-o
Svaka cast, HVALA!
Ja uglavnom kužim o cemu se tu radi, 2-3 rijeci mi nisu jasne, ako ne bude nitko prije budem ja sutra navecer to preveo kak treba jer idem spavat sad i postavit tu na forum, ovak zvuci jednostavno ali treba nabavit taj materijal i malo se igrat pa kaj bude bude
jedini problem predstavlja pec, di nabavit tak veliku da ti stane cijelo staklo unutra  :?
po meni najjednostavnije bi bilo kad se vec ide chopat dat napravit od plexia, ionako bi bila zatamnjena stakla, mislim da je to jednostavnije za napravit
Offline Mini_Filip
  • Postova: 664
FI
« Odgovori #33 : 05 Prosinca, 2006, 00:36:09 »
bravo Vlatkec!
Plexi ce ti se zgrebati jako brzo i naravno nece nikada izgledati kao staklo, a brisace mozes zaboraviti jer ce metlice napraviti riseve nakon prvog puta kaj ih aktiviras...
imported_Gear
FI
« Odgovori #34 : 05 Prosinca, 2006, 00:55:12 »
gledao sam na overhaulinu neki trik,   zarezao je staklo, zalio necim zapaljivim zapalio staklo,  dok je plamen bio, on je migimigi s klijestima staklo micao i puklo tocno po rezu.  :shock:
Brutalac
FI
« Odgovori #35 : 05 Prosinca, 2006, 04:13:38 »
Thank you, thank you ,thank you  :o
Tracker
FI
« Odgovori #36 : 05 Prosinca, 2006, 09:02:04 »
Evo ja sam preveo to nabrzinu...
"Novi prozori su morali biti napravljeni da bi stali u manje otvore.To je  jednostavno za bocne prozore,zato jer u ravni.Ali kako napraviti one zakrivljene prednje i zadnje prozore?
Prvo treba napraviti kalup od trake metala,širine 2cm i 3mm debljine,koja tocno odražava vanjsku liniju prozora.Možete ju pojacati sa nekakvim nosacem da se ne uvija kad ga stavite u pec.Onda treba napraviti šablonu od kartona i izrezati dva komada stakla po toj šabloni.Staviti jedno staklo u kalup,staviti u pec i staklo ce se saviti prateci liniju kalupa.Onda staviti plasticni list na staklo i preko njega staviti drugo staklo,onda opet vratiti u pec,i evo ga jedno svježe peceno "linato" staklo.Zadnje se staklo radi na potpuno istom principu."
Jako zanimljiv princip,i jednostavan.Jedino mi malo nije jasan ovaj list plastike,valjda on služi da slijepi stakla da ne puknu u oštrim komadima u slucaju pucanja.  :noidea:
Jer znam da obicna šajba na autu ima neku gumastu masu u sebi na kojoj staklo ostane zaljepljeno,pa kad puca saspe se u zrnje,a ne u plocama.
A što se tice peci,možda zamolit u pekari ili pizzeriji ako netko ima nekoga poznatog tamo,pa tamo ispeci stakla  :D
Brutalac
FI
« Odgovori #37 : 05 Prosinca, 2006, 14:34:23 »
U svakom slucaju ako netko ima shemu i zna kako to napraviti neka nas sve obavijesti...ko zna...mozda jedan dan chopanje bude obavezno :evil:
Tuco
FI
« Odgovori #38 : 05 Prosinca, 2006, 19:25:29 »
nije to baš tak jednostavno kak se cini, to bi onda svi radili kao od šale,  orginal prednja šajba ima foliju izmedu staklenih ploha upravo zbog zaštite jer bi kod pucanja iste vozacu i suvozacu razderalo lice i to gadno!
Pizza pec jako teško, jedino ak se pazi jako na temp. jer se temp. kod pecenja pice krece i do 1600-1800*C
Nece bit ništa od toga ako ne nadem nekog ko zbilja zna kako se to radi
crank
FI
« Odgovori #39 : 05 Prosinca, 2006, 20:50:35 »
nadji nekoga ko radi sa staklom ,pa ga pitaj tu mora biti tacno propisana temp ,nadji nekog u nekoj fabrici stakla,pa pitaj
Tracker
FI
« Odgovori #40 : 05 Prosinca, 2006, 22:27:01 »
Pa koliko znam pec bi trebala imat regulaciju temperature
Ili strpaš još dok se zagrijava i onda brzo izvadiš van kad dobije oblik :)
Tuco
FI
« Odgovori #41 : 06 Prosinca, 2006, 00:37:07 »
Tracker: da, elektricna ima regulaciju ali krušna nema, kolko trpaš tolka je temperatura, i šamotne opeke cine svoje...no dobro, otišli smo previše u OT  :)
Offline Mini_Filip
  • Postova: 664
FI
« Odgovori #42 : 06 Prosinca, 2006, 11:59:09 »
ne znam. mislim da to nije samo tako.
cak i da uspije, i da nema nikakvih mjehura po sebi i da je savrseno napeta i glatka, tko ti garantira da ti se nece rasipati odjednom negdje na cesti dok si daleko od doma.
Tuco
FI
« Odgovori #43 : 06 Prosinca, 2006, 12:03:02 »
Upravo to, nije to baš za zajebanciju..
Tracker
FI
« Odgovori #44 : 06 Prosinca, 2006, 20:48:25 »
A jebiga,koliko sam skužio,izrada i nije tako extra skupa,mislim,staklo i to
Treba probat napravit,a ne tapkat uprazno,kad se napravi,isprobat na raznorazne nacine,netreba na autu,al recimo podvrgnut ju nekakvim uvjetima prirodnim,npr. sa miniwashom ju derat,zagrijavat hladit,bacat kamencice ili kamenje,uglavnom,vidjet kako se ponaša i dal je i koliko otporna na te stvari
