Autor Tema: moja nippon gambare kola...  (Posjeta: 3016 )
rio
« : 20 Prosinca, 2008, 00:19:47 »
celica st 162
2.0 gti 16 v - 1987
103 kw po papirima ;)
farbanje prije 4 godine
gotova kola
daily beater, snow touge car. itd. itd..  :evil:
nesto malo exskluzivnije i rjede na ovim prostorima barem ;)
celica st 165 gt turbo 4x4 16v . a.k.a GT-Four. a.k.a AllTrac.
a.k.a The Belanka :)  :roll  :o
Toyota Celica ST165 GTFour Specs (1987-1989)
Type 3S-GTE. Cast iron block, aluminum head construction. Transversally mounted.
1998 cm3 , water cooled in-line 4, 195 Bhp@6000 rev/min, 240 NM@3200rev/min.
Bore: 86mm, stroke 86mm compression ratio 8.5:1. Toyota CT26 oil lubricated , water cooled turbo (0.7 bar max. pressure) and water/air intercooler. 2 OHC belt driven and hydraulic tappets. 4 valves per cylinder (50°). Oil cooler. Electronic fuel injection (Bosch L-Jetronic licensed ).
Transmission
All wheel drive. Central viscous coupler, Torsen rear differential. Epicyclical center differential with 50-50 % F/R distribution. Final drive ratio 4.285:1
Five speed fully synchronized gear box.
Gear ratios - speed at max. RPM:
1: 1:3.583 - 43 Km/h
2: 1:2.045 - 76 Km/h
3: 1:1.333 - 117 Km/h
4: 1:0.972 - 160 Km/h
5: 1:0.731 - 213 Km/h
Reverse: 1:3583
Single dry plate clutch.
Suspension
Front: independent strut located by a control arm, coil springs, anti-roll bar, telescopic dampers.
Rear: independent strut located by one trailing link and two lateral links, coil springs, anti-roll bar, telescopic dampers.
Brakes
Front: Vented disks (254 mm) floating 2 pot calipers.
Rear: Disks (265 mm) floating 1 pot calipers.
4 sensor ABS
Steering   Power assisted rack wheel and pinion, 2.9 turns lock to lock
Chassis
Monocoque steel construction.
Wheels/Tires
7½"x16" wheels, 195/60 VR 14 tires
Dimensions   Length: 4365mm
Width: 1690mm
Height: 1295mm
Wheelbase: 2525mm
Front track: 1465mm
Rear track: 1440mm
Laden weight: 1350Kg
Performance   0-100Km/h acceleration: 7.7S
Max speed: 215Km/h
0-1000m acceleration: 28.2S
to je the projekt, za kojeg vecinom skupljam djelove vec 2, 3 godine ali se skupila kriticna masa neka...
i sadda bi trebalo to ovako nekako izgledati...
 :o
i zavrsiti nekako ovako
ili ovako mozda  :evil:
Offline Noukz
  • Postova: 191
    • http://www.sajsiga.ba
« Odgovori #1 : 20 Prosinca, 2008, 00:28:21 »
Sorry, ali ako sam dobro razumio, imas dvije?  :o  162-ku i GT-four?  :shock:  You lucky bastard!  ;)  Svaka cast! Me like... :evil:
Ložim se na trule Opele, a vozim truHlog stojadina.ba
rio
« Odgovori #2 : 20 Prosinca, 2008, 00:45:02 »
racunaj jos jedno 3 162, 1 st 165/8 u gro stvari u djelovima,,
ali moras ih skupiti sve , ko pokemone..  :dance:
ako ko ima informaciju o kakvoj sta 165
 185
ili 205
za djelove, stucanoj, itd, neka vice
moze i st 162 , ra 28, starlet kp61, bilo tera stara toyota usotalom ;P--
info, slike, djelovi, itd..  :dance:  :bye:
Offline Noukz
  • Postova: 191
« Odgovori #3 : 20 Prosinca, 2008, 00:57:11 »
Wow! :sok: Respect, maan! Heheh, fali ti jos koja od starijih generacija A20, 40, 60...  ;) Sve su selike uvijek bile super auta... A20 my fav...  :)
Znaci radis najvise na bijeloj GT-four? Sta, koliko, cega, kada... blahblah...?
 :D
rio
« Odgovori #4 : 20 Prosinca, 2008, 00:59:48 »
radi se nmalo, skoro nist,a sada sam skupio kriticnu masu djlova ,citaj nemam kamo vise slagati jedno 300 kvadrata sam natrpo svega valjda...
pa je vrijeme da ju slozim ;)
Offline Noukz
  • Postova: 191
« Odgovori #5 : 20 Prosinca, 2008, 01:04:22 »
Ma samo nek ima djelova, naci ce se i vremena nekako... Srecno s radovima!  :bravo:
I da je slozis kao onu rally sa slibe! Heheheh  8)
Offline kizo
  • Postova: 947
« Odgovori #6 : 21 Prosinca, 2008, 11:33:28 »
Lijepa kolekcija Rio
Pale valjda prodaje svoju štiri x štiri
rio
« Odgovori #7 : 23 Svibnja, 2009, 00:37:08 »
mogao bi da se vadi mator za koji dan,  ali prije toga mi fali samo jedan lajtung za ulje za trubinu da malo upalimo vozilo i prevezemo se ko ljudi iz jedne garaze u drugu........ :o
e da pale definitivno ne prodaje, jedan drugi pakleni plan je u pogon lagano bas danas krenuo...
