Autor Tema: da malo cjepim ovaj forum sa nippon gambare kolima ;)  (Posjeta: 8198 )
rio
« : 20 Prosinca, 2008, 22:18:39 »
lekcija 1.
trd starlet kit car  :o
http://img454.imageshack.us/img454/224/kp61trdkitaf92999vt6.jpg
Here's a pic of a race prepared TRD 5K Engine.
SOLEX
3k-r restored to its former glory, 180bhp@ 11,000rpm  8)
heres one i found in japan  :cry:
and heres one back in the day....
heres an original tosco 4 branch, set of solex 40's and inlet manifold for TRD cup car
 :evil:
rio
November 24, 1973 Grand Champion fifth race Fuji Speedway Vi
« Odgovori #1 : 20 Prosinca, 2008, 22:21:42 »
November 24, 1973 Grand Champion fifth race Fuji Speedway Victory 200
Sunny is Defeated by DOHC Toyota
minor touring class
The day that lives in infamy, as the Sunny sweep comes to an end at the hands of the Toyota Starlet DOHC 4-valve engine.
Red Starlet leading Yellow Sunny
Note the blue cam cover. Nippondenso fuel injection. Dry sump oiling.
Note the 30-degree high bank track
Based on the Toyota 3K engine of 1166cc, engine was increased to 1293cc. The result? 180ps (hp) @ 9500 rpm. Torque 14.0 kg at 7000rpm. Starlet is fitted with front and rear spoilers, tubular a-arm suspension and a differential oil cooler. Although having a heavy weight of 717kg (about 100kg heavier than Sunny), with its power-to-weight ratio of 3.9kg/PS vs. the Sunny's 4.0kg/PS, the Starlet's perfomance was better.
1. Hisashi Toyota Starlet
2. 舘 信秀 Toyota Starlet
3. Kenji Takahashi Technica Sunny
4. Hoshino Cherry coupe 1200XIR
5. Takatoshi Cherry coupe
6. Yutaka Masa Shibata Sunny 1200 coupe
more pix of the 3K-R
rio
Starlet cup cars...
« Odgovori #2 : 20 Prosinca, 2008, 22:24:25 »
Offline domagoj
  • Postova: 170
« Odgovori #3 : 20 Prosinca, 2008, 23:07:10 »
Interesantan izbor karburatora: Solex i Dellorto, pored domacih Mikuni i Keihin. :?
Kawasaki ZX-7RR N1
Kawasaki ZXR 750R K1
rio
« Odgovori #4 : 20 Prosinca, 2008, 23:50:27 »
mene vise zanima ovaj mehanicki einspritch sa tb-ovima LOL
Offline Ivan L
  • Postova: 1172
« Odgovori #5 : 21 Prosinca, 2008, 00:07:28 »
Ne treba te buniti izbor Solexovih karburatora. To su Solex-Mikuni (licenca).
Dellorto nisam primjetio da se u tekstu spominje.
« Odgovori #6 : 21 Prosinca, 2008, 00:33:28 »
ma sve je to super al frende moga si malo i privest jer je ovo  samo copy/paste
Offline celica 1976
  • Postova: 221
« Odgovori #7 : 21 Prosinca, 2008, 01:54:56 »
kak bi to ljepo ležalo u mojoj celici.
Offline kizo
  • Postova: 947
« Odgovori #8 : 21 Prosinca, 2008, 11:28:11 »
taman za Sljeme   8)
rio
« Odgovori #9 : 25 Prosinca, 2008, 00:31:09 »
Citat: Ivan L
kad smo vec kod toga...
Offline kizo
  • Postova: 947
« Odgovori #10 : 25 Prosinca, 2008, 13:39:28 »
usisna grana je  :haha:
Offline BackFlash
  • Postova: 640
« Odgovori #11 : 25 Prosinca, 2008, 15:26:10 »
usisna je koda sam je ja vario :D
« Odgovori #12 : 25 Prosinca, 2008, 19:25:56 »
Not Something You See Everyday
From 1972 to 1977, Mazda’s entry into the Japanese Kei Car market was the Chantez. Unlike the kei-cars of the 80s onwards, the 70s Keis were nothing special technologically, and the Chantez was no different. Whereas 80s Keis had 4 (or 5) valves per cylinder, twin cams, fuel injection and turbos to compensate for their dinky 660cc capacity, the 72 Chantez debuted with a 360cc 2-stroke V2….now I’m not really sure how much power the stock Chantez put out but it’s safe to assume that it was not a lot.
But the thing that attracted Ama-san (from famed rotary workshop RE- Amemiya) was that the Chantez, for all its shopping car mediocrity...was rear wheel drive. And there was just enough room between the shock towers for a 12A rotary...
Here’s what a stock one looked like...
And this shot shows you how tiny the little Chantez really is...
This shot of the stock motor shows that it’s tiny…in fact the air cleaner dwarfs the engine itself...
But the Amemiya beast has a 12A turbo, with an old school blow-thru Weber downdraught carb setup. Exact power isn’t quoted but it was tested by Option magazine in the 70s as having a 240km/h top speed!
Word has it that the Chantez was quite a well known car in illegal street racing circles over 25 years ago, and Ama-san himself would cruise the arrow-straight Tokyo freeways in it, terrorising unsuspecting sports car owners.
Here’s a vid of it in action.
http://www.youtube.com/watch?v=Qn10aUzhi-o
In the late 80’s there was a tv show in Japan called “Kuruma Wa Erai” where viewers and tuner shops would pit their cars against each other in televised drag races (awesome concept by the way) and here is the episode which featured the Chantez, which took down quite a few contenders before succumbing to mechanical failure (well...it is a rotary!)
