Autor Tema: R4 GTL - hobi projekt  (Posjeta: 47982 )
Offline John Doe
  • Postova: 245
Odg: R4 GTL - hobi projekt
« Odgovori #60 : 08 Ožujka, 2016, 14:58:39 »
Sto se tice kilometraze i cetvorki, evo sta kaze covjek iz Atine :)
"When my family bought my '75 R4 in 1990 it had 195.000 kms. Add to this 250.000 kms until 1996,and another 79.000 up to today...sum 524.000 kms. Only one engine repair at around 480.000 kms due to overheating (my fault). About one year ago, I went to see a fairly good looking '72 model. When I asked the owner about mileage, he said casually "around 800.000 kms" ,without fearing that I would turn away (I admit it ran very well). We have (had...) a lot of such high-mileage R4s here in Greece, for two reasons:The climate does not allow them to rust quickly (the mechanics last infinitely) and, due to vehicle tax system, many people had an R4 as their one and only car for 20+ years (not as second or third as in many other countries),therefore most of the remaining R4s have around 300.000 kms.
But certainly the record-breaking R4s were those of the National Electricity Company and also Greek Telecommunications Organisation. They were used for network support vehicles all round the country from '69 to '97 (this means the fleet was built of '69-75 R4s, that were not being "refreshed"). They were abused by the network technicians, but maintained fairly well,and logbooked. It was not uncommon for a lot of R4s to reach the 1.500.000 kms mark, as some technicians have told me.A few "lucky" of them,that had lower mileage, are still in service today. "
« Odgovori #61 : 08 Ožujka, 2016, 15:55:18 »
Izdrzljive su mazge ali milja i po hm..mozda malo ipak pretjerivanja. Oko 300 ljami prosjek oce ona..znam da su svi vozaci u domu zdravlja kukali kad su ih morali umirovit..nesto sl kao apeni u posti...
« Odgovori #62 : 08 Ožujka, 2016, 15:56:19 »
A i posta ih je derala danonocno u krug
Offline John Doe
  • Postova: 245
« Odgovori #63 : 08 Ožujka, 2016, 19:11:03 »
Ja sam gledao jednom u njemackoj neki svecenik ima R4 sa 850k km... doduse uz popravke. Ovo gore pise covjek koji je strucnjak za R4, ima par rijetkih modela i definitivno mu se ne moze pricati price :)
Offline petak
« Odgovori #64 : 09 Ožujka, 2016, 21:47:55 »
Evo me nazad društvo!
Znam da ste dugo čekali ali bili su ovo vrlo užurbani dani iza mene.
U prijašnjem nastavku ste pratili slaganje samog motora.
Nakon toga ga mu je trebalo nadograditi ostale dijelove bez kojih nemože u auto.
Za početak sam krenuo sa vodenom pumpom
Stara i nova radi usporedbe
Pa je sa stare skinuto sve što treba prebaciti.
Složen je jedan "expode view" za lakše snalaženje kod vračanja.
Svi nosači, vide, matice, podloške su poslane na galvanizaciju.
Nova pumpa sa svojim vijcima i brtvom
Namonitirana pumpa na motor
I stavljena remenica za pokretanje
Pa sam onda odlučio staviti kvačilo, ali prije je trebalo zamijeniti  neke brtve i semeringe koji idu prije kvačila
Velika brtva ispod zamašnjaka
Stara
Nova
Skinuta stara
Očišćeno koliko se moglo
Stavljena nova
Zamjenjen semering na bregastoj
Pa je stavljen zamšnjak.....ovdje je bilo malo panike jer nisam zabilježio kako je stajao zamašnjak prije skidanja......ali nakon studiranja i pokušaja došao sam do zaključka da raspored rupa na zamašnjaku nije simetričan i da je samo jedan mogući način postavljanja zamašnjaka da sve rupe pašu....jednostavan način kakose osigurati od nenamjene greške. Tko god da je to smislio svaka mu čast
Pa onda kvačilo
Novo, valeo set
Blago unutar kutije
Centriranje lamele
Centriranje korpe
Potisni ležaj je čekao mjenjač
I jedna slika operacijskog stola sa pacijentom
Offline petak
« Odgovori #65 : 09 Ožujka, 2016, 22:35:17 »
Ali da bi stavili mjenjač prije je trebalo zamjeniti brtve na izlazu poluosovina
Alat za skidanje metalnog poklopca (ižinjavanje na 100 :rotfl:)
Otvoreno
Brtva na navoju (mala tanka gumica velikog promjera)
Brtva na otvoru kroz koji poluosovina ulazi u mjenjač
Sad možemo spojiti mjenjač i motor. Potisni ležaj je postavljen na svoje mjesto i podmazan kako bi lakše klizio po osovini
Spajanje
U međuvremenu je stavljena usisno ispušna grana
Sa temperaturnom zaštitom
Glavina
Glavina sa brtvom
Grančica
Ovdje se vidi kako zaštita stoji (slika je snimljena puno kasnije)
Sad imamo na redu njegovo visočanstvo karburator....močni i vrlo jednostavni ZENITH 28 IF
Postavljena brtva/distanca (negdje sam pročitao da debljina ove brtve ima veliku ulogu u radu karburatora.....nebi znao ali bi volio ako netko zna nešto više o tome....kako debljina ove brtve može utjecati na rad karburatora pa onda i motora)
Karburator na svom mjestu
Pa postolje filtera koje ide na vrh karburatora. Postolje je očišćeno od stare boje, poslano na galvanizaciju pa na plastificiranje)
Spremno za montažu
Montirano
Fali još samo poklopac filtera ( i on je očišćen od stare boje, galvaniziran pa plastificiran) Packe od prstiju zanemarite :bigl:
Na kraju to izgleda ovako nekako
Offline petak
« Odgovori #66 : 09 Ožujka, 2016, 23:08:28 »
Kad je to sve složeno bio je red na strujne agregate na motoru.
Alternator - Iskrin
Nosač s kojim se drži za motor
Expode view
Malo sam ga rastavio, očistio, promjenio četkice, ležajeve na rotoru, dao ispitati kod profesionalca
Stanje i nije bilo baš bajno jer je dugo stajao i napalo ga je svašta
Taj isti alternator sada fino puni i radi na čvrkici
Naravno da sam morao i starter pogledati.
Kad ga rastavite na sastavne dijelove to Vam izgleda ovako
Stator i četkice
Nove četkice
Zalemljene i spremne za ugradnju
Posložene na svoje mjesto i ubačene u stator
Rotor
Prebrušena dodirna ploha
Ubacivanje u stator
Slaganje poluge kojom se zupčanici izbacuju is startera i hvataju u koštac sa zamašnjakom
Nabacivanje
Automat
Povezivanje kablovinja
Završni dodir (zaštitna kapica)
I završen proizvod.
Nakon ovoga je odnešen na testiranje kod profesionalca koji nije imao ni jednu primjedbu na rad i obavljeni posao
Offline petak
« Odgovori #67 : 09 Ožujka, 2016, 23:30:29 »
Za kraj današnje epizode sam ostavio još par sitnica koje idu na motor
Natezač remena vodene pumpe
Pa rastavljen
I poslan na galvanizaciju
Slaganje
Spreman za montažu
Evo ga na svom mjestu
Nosači motora
Predni koji ide namjenjač
Njegova pozicija
Montiran
Desni
Ugrađen na svoje mjesto
Lijevi
Alternator ugrađen na motor
Nova pumpa goriva
Za večeras dosta.....pratite i dalje......molim strpljenja jer kradem vrijeme od samoga sebe da ovo posložim na forum.
Vjerojatno koji korak i preskočim (zaboravim) ali nije namjerno......puno je toga
« Odgovori #68 : 10 Ožujka, 2016, 07:27:16 »
pedantno nema šta...oce trajat to cca 30 godina još?? haha...
Offline XB_coupe
  • Postova: 517
  • Thanked: 11 times
  • Lokacija: Podstrana,Split
  • Vozilo:: Peugeot 305
« Odgovori #69 : 10 Ožujka, 2016, 07:40:04 »
Vrhunski svaka čast, Petak Haynes  :whistle2:
Respect your elders
« Odgovori #70 : 10 Ožujka, 2016, 08:28:24 »
Debljina te brtve ispod karburatora je ''distancer'' koji ima dvojaku ulogu...
Prvo - da se karburator toplinski ne opterećuje i da se uslijed istog ne deformira baza difuzora u kojoj je leptir zraka. Znaš i sam da se baza karburtora izvije, a sam difuzor oko leptira ''ujajasti'' i onda imaš nekontroliranu zračnost oko leptira zraka. Takav karburator ne možeš naštelati ama baš nikako da dobiješ ono Čvrkinu ''drugom sto, a inače troši 5 lit/100km''.
Drugo - mlaz (sprej) goriva koji se pretvara u gorivu smjesu nastaje na točno određenom mjestu i sa Tom distancom smjesa treba biti ''onakva kakva treba biti'' na ulasku u usisnu granu. Ovaj dio je ''nja nja'' više teoretski... Ne vjerujem da ijedan prosječni vozač može ''pod nogom'' osjetiti razliku koju čini debeljivost  ;D ove brtve.
Treće - bez te distancer brtve karburator se više grije. Osim što se dešava ovo pod ''Prvo'', dešava se da ti nakon gašenja motora karburator ostane bez goriva Koje jednostavno - ispari. To je ono ''Dragi forume... Auto mi teško pali nakon gašenja. Inače pali na pola ključa, ali se zna desiti da nakon gašenja jednostavno ''crkne'' i jedva ga upalim...'' pa se ovom problemu pokušava doskočiti sa onom vječnom filozofijom ''ovaj šaraf dva kruga odvrni, a onaj zavrni do kraja pa odvrni Krug i kvarat...''  ;D
Također... Ajmo reći ''četvrto''  mada nema veze sa ovom brtvom... Za ispravan rad karburatora neophodno je da je paljenje (naštelanost kao i ispravnost istog) besprijekorno, da su ventili poštelani i ono što dosta majstora napravi ''ma to zabrikaj, to ti ne treba'' - onaj sustav iberlauf cjevi sa pripadajućim ''T-reducirom'' spojeni kako treba, bez zračnosti odnosno da je ''T-reducir'' nezaštopan.
Upravo je ovaj ''T-reducir'' ključ za ''druga sto, a troši 5 lit/100km'' kao i za Miran rad motora i - ispušne plinove i potrošnju.
Znači... Šta smo ono imali od dvojake uloge... Distanca... Isparenje goriva... aaammMMMmmm iskrivljenje... I digitalizacija...  ;D
« Zadnja izmjena: 10 Ožujka, 2016, 08:33:55 frik-ri »
Offline Brother
  • Postova: 214
  • Lokacija: Rijeka
  • Vozilo:: BMW 2002
« Odgovori #71 : 10 Ožujka, 2016, 12:22:45 »
  :lol: :lol: kratko i jasno da ne poželiš bez brtve,uvijek samo sa brtvom. :lol: :lol:
« Odgovori #72 : 10 Ožujka, 2016, 12:52:48 »
Bez brtve ti se iskrivi....
...pa pocrveni.....
....pa pocrni....
....pa otpadne.....
To Frik iz iskustva govori  :anal:
« Odgovori #73 : 10 Ožujka, 2016, 21:34:45 »
Nije to brtva, brtve idu na to a to ue bakelit,vrlo uednostavno jer ne gori i slabo provodi toplinu.
A sto se dotikavle goriva to se mora rasprsiti jos u karbu jedino ako nije kod renjola drugacije.
Sorry petak patak na off.
Offline petak
« Odgovori #74 : 01 Travnja, 2016, 22:45:23 »
Evo me nazad društvo....dugo me nije bilo.....što poslovne obaveze što obiteljske...večeras novi nactavci sapunice...
Vidili ste kako sam prednji ovijes rastavio i očistio od ruzine i boje pomoću struje (elektrolizom)
Zadnji most sam odlučio ostaviti kakav je odnosno ne rastavljati ga iz jednostavnog razloga jer me je bilo strah da ga neću uspjeti sastaviti nazad. zato sam ga cijelog uronio u elektrolit i očistio od ruzine i pripremio za zaštitu.
Neke slike postupka
priprema korita
Kontrola dimenzija
Priprema elektrolita
Spajanje na struju
Struja
Kuvanje
Nakon što sam most izvadio iz elektrolita dobro sam ga oprao visokotlačnim peračem i ostavi oda se osuši i ocijedi.
Pa onda leteči preletio žičanom četkom...da ga malo izgladim....pa premazao IVARAST-om da neutraliziram ruzinu
Ulijevao sam i u ramena IVARAST da se sve fino natopi.
Nakon toga primer i crna boja pa lak
Završni proizvod izgleda ovako
PA sam se bacio na opremanje zadnjeg mosta odnosno ubacivanje zadnjih kočnica
Prvo sam morao doboše urediti. stari su bili još daleko iznad granice donjeg minimuma tako da nisam nove nabavljao
Priprema je rađena na isti način.
Elektroliza, ispiranje vodom, IVARAST, primer, crna mat boja i lak
Kako sam imao donora onda sam mogao izabrati doboše u najboljem stanju
Ležajevi i kočnice su uzete nove
Pripremljeno sve za montažu
Ugradnja stražnje ploče na kojoj se drže pakne i cilindar
Dijelovi kočnice
Kočioni cilindar i prsten unutarnjeg ležaja
Pakne postavljene
Provlačenje sajle ručne kočnice (nova)
Uprešavanje ležaja na bubanj
Klizni prsten
Ležaj namazan
sa mašću
Zaština brtva
Vanjski ležaj
