Autor Tema: Mini - (update str. 28) Type R Mini  (Posjeta: 226299 )
Tracker
« Odgovori #150 : 03 Travnja, 2007, 21:08:15 »
Ajme,za sve ovo 150kn  :shock:
Cijeli cu auto onda u to stavit  :haha:
Prejebeno,jel može kakav kontakt broj od tog decka?
Offline aske777
  • Postova: 254
« Odgovori #151 : 03 Travnja, 2007, 21:28:42 »
The result is a uniform, durable, high-quality, and attractive finish. Powder coating is the fastest-growing finishing technology in North America, representing over 10% of all industrial finishing applications.
Powder coating produces a high specification coating which is relatively hard, abrasion resistant (depending on the specification) and tough. Thin powder coatings can be bent but this is not recommended for exterior applications.
During installations, the powder coating should be protected from damage due to abrasion and materials of construction such as mortar and brick cleaning chemicals.
Once installed, maintaining the initial appearance of a powder coating is a simple matter. The soot and grime which builds up on surfaces from time to time contains moisture and salts which will adversely affect the powder coating and must be removed. Powder coatings should be washed down regularly (at least once each 6 months in less severe applications and more often in marine and industrial environments). The coating should be washed down with soapy water -- use a neutral detergent -- and rinsed off with clean water.
http://www.finishing.com/Library/pennisi/powder.html
http://www.powdercoating.org/benefits/
http://www.p2pays.org/ref/01/00777/alternat.htm#Advantages%20and%20Disadvantages%203
evo pa citajte ako ne vjerujete... ja da sam bliže nebi se dva puta promislio odmah bi nosio... a još tako jeftino..
ITB+MEGASQURT+6A+KR= 190BHP
Offline Mini_Filip
  • Postova: 664
« Odgovori #152 : 04 Travnja, 2007, 02:15:53 »
Tracker - vrati se na prethodnu stranicu i na kraju mojeg posta o plastificiranju ceš lijepo vidjeti kontakt - ime, telefon, adresu, email, web stranicu...
Aske - pa zato sam i odnio hrpu stvari na plastificiranje! :)
Pitao sam lika dali preporucuje plastificiranje aluminijskih dijelova i kaže da nema problema jedino se zna dogoditi na nekim legurama aluminija da izbije masnoca iz legure pa ostavi trag, tipa tockice ili flekice. treba isprobati! mislim da cu neke alu stvari nositi njima ali za tjedna dva...
AlfaZD - što se tice niklovanja i kromiranja. Postoji taj Hrvoje Patafta u Zagrebu koji kromira. nosili smo mu vec neke dijelove, to su uglavnom bili neki nosaci, poklopci ventila i takve sitnice. sve smo morali sami obraditi. jednom sam mu odnio kompletno sve šerafice i oprugice od duplih fergazera za minija. uzeo mi je 600kn za to!! to je bilo prije 6-7 godina. na nekim osovinama se krom poceo ljuštiti iako uopce nije bio debel sloj.
nedavno je Silvio sa foruma nosio dijelove kod Patafte na kromiranje i bio je jako zadovoljan, cijena je isto bila ok! isto tako je još jedan naš Mini prijatelj furao dijelove kod njega i takoder je jako zadovoljan sa kvalitetom i cijenom. navodno se taj Patafta preselio na žitnjak i ima kompletno novi pogon i još više radne snage.
Meglaj, moj lakirer, je rekao da u hrvatskoj još nije našao nikoga tko dobro kromira i da on nosi sve u Ljubljanu.
Ovo što sada pripremam za niklovanje i kromiranje cu nositi kod nekog novog covjeka koji se nedavno poceo baviti time tako da cemo vidjeti kako ce to ispasti. kada bude gotovo cu sve poslikati i staviti na forum.
koliko sam skužio fora je u tome da koliko si dobro sam pripremiš dijelove toliko ce dobro kromiranje i ispasti!
eto, to su iskustva, mišljenja su podijeljena. predlažem da pricekamo da se meni ponikluju i pokromiraju dijelovi pa cemo vidjeti omjer kvalitete i cijene!
toliko za sada...
Offline AlfaZD
kromiranje 2
« Odgovori #153 : 04 Travnja, 2007, 06:58:42 »
Hvala na informaciji.
Mi smo u Zadru do pred 15-16 god. imali obrtnika koji je izvanredno kvalitetno niklovao,
kromirao, ili aluminij samo polirao. Otisao je u mirovinu, a nitko ga nije naslijedio. Nije bio bas jeftin, ali kvaliteta je to opravdavala. Dan danas zalim za njim.
inace, pravi postupak ide ovako: predmet treba  ocistiti od boje ili masnoce -  obicno
 vlasnik . Dalje bi trebao raditi majstor.
1 - poliranje
2 - nanosenje sloja bakra u elektrolizi
3 - poliranje
4 - nanosenje sloja nikla u elektrolizi
5 - poliranje   /  ako je zelja niklovanje, = gotovo!  ili:
6 - nanosenje sloja kroma u elektrolizi
7 - poliranje  /  konacno gotovo.
S obzirom koliko posla tu ima, ako je jeftino, strah me za kvalitetu. Momentalno ne znam za
nikog provjereno kvalitetnog u Hrvatskoj, cuo sam za tog u Ljubljani, a prijatelj iz Selca je nosio
dijelove u Padovu. Napravljeno savrseno. Ali, taj auto je "55 god.
Offline dr_t
  • Postova: 637
« Odgovori #154 : 04 Travnja, 2007, 07:34:32 »
zakonnn sad svi sve na plastificiranje...nisam znal da to postoji u hr gledal sam na discovery channel kak slažeju ameri chopere... i sve rame plastificiraju...i veli lik da ako lupiš cekicem po tome prije bude se željezo udubilo nego da se lak ošteti...
Brutalac
« Odgovori #155 : 04 Travnja, 2007, 14:07:17 »
Citat: dr_t
EEEEEE pa takvo plastificiranje mene zanima!!!
Jel mozda znas dal je to nekaj posebno ili najnormalnije plastificiranje?? :?
Offline aske777
  • Postova: 254
« Odgovori #156 : 04 Travnja, 2007, 14:12:10 »
imaš ih više vrsta... zavisno od aplikacija. moguce da ovi kod goga se plastificiralo nemaju takvu smijesu.. ali ameri to koriste za sve živo.. od cilih motora pa do šarafa... prekrasan je ima više završnih boja... crna je nešto ka standard.. imaš i žuti, crveni, plavi itd... nemaš sada baš u nijansama ali ima se vecina boja... pa ja nemogu virovati da tako nešto ima u nas...  ljudi koristite ovaj proizvod u što vecem broju... zakon je .. da bar ima ko u splitu... joj
Brutalac
« Odgovori #157 : 04 Travnja, 2007, 14:25:24 »
Di i kak se moze saznati kakve su to sve vrste?? :?
A sto se toga tice da nema u Splitu...
Pa nije Zagreb na drugom kraju svijeta...
Natrpas djelove po kutijama i pravac ZG...Mislim da bi ti se isplatilo  ;)
Offline Mini_Filip
  • Postova: 664
« Odgovori #158 : 04 Travnja, 2007, 15:12:36 »
tj. pošalješ busom a neko od nas predigne i odnese na plastificiranje.
imported_Gear
« Odgovori #159 : 04 Travnja, 2007, 17:20:23 »
2 vlatko, to bi ti vrata trebao plastificirat da se kljuc svine kad netko stisne.  :P
ovo za krom znam da nema nikog tko to bas radi jako kvalitetno, a i taj ventildekl od silvija mi nije ostavio neki dojam kvalitete, makar bi ja bio zadovoljan i stime.
znaci ici cemo svi do tog decka... inace Rio s hraweba isto radi plastificiranje i pjeskarenje, ja sam mislio njemu nosit svoje dijelove, htio bi svakako cijeli ovjes i mostove s diferencijalom u powder coating.
Offline dr_t
  • Postova: 637
« Odgovori #160 : 04 Travnja, 2007, 18:52:57 »
ja mislim da je sve to isto taj prah se šprica posebnom špricom, prah je pozitivno nabijen a ono kaj se farba je negativno zato se prah prihvati na to i onda se pece oko 30 minuta na 200 stupnjeva celzija...
Brutalac
« Odgovori #161 : 04 Travnja, 2007, 23:16:43 »
Citat: Gearhead
Kaj mislis da bi mu bilo zao kljuca ili da ima samo jedan pa bi stao kad se taj spiga  :?
BTW kaj samo vrata???Pa cijeli auto mi je zgreban  :cry:
JOJ ŠTA BI IM....BIP BIP BIP  >:(
Offline Mini_Filip
  • Postova: 664
« Odgovori #162 : 05 Travnja, 2007, 02:17:57 »
Citat: Gearhead
...taj ventildekl od silvija mi nije ostavio neki dojam kvalitete...
s obzirom da nitko (od ovih koji kromiraju) ne polira ništa nakon svake faze najviše ovisi o tome kako si sam pripremiš dijelove. moja niklovana kapa ventila izgleda puno bolje od ove Silviove kromirane, slažem se...
peugeot_bebe
« Odgovori #163 : 07 Travnja, 2007, 17:12:20 »
Svaka cast Filip....
 :D
Jedva cekam da ja pocnem sa ficom...
Offline Mini_Filip
  • Postova: 664
« Odgovori #164 : 07 Svibnja, 2007, 22:35:32 »
a ja se i dalje bavim glupostima, još nekoliko stvari sam dao plastificirati, vec treci puta odnio stvari na cincanje a sada sam potrošio malo novaca na šajbice i pleh šerafe od inoxa. a kaj da vam kažem, veseli covjeka!
što se kromiranja tice. odnio sam prije par tjedana dijelove na kromiranje onom Patafti o kojemu sam vam pricao. pogledao sam kako rade i moram priznati da rade jako dobro ali su zato i cijene takve.
nakon što sam se kao konj izmucio sa poliranjem svojih dijelova za kromiranje oni su mu rekli da to treba još polirati jer ce se vidjeti svi risevi. uglavnom, ostavio sam im dijelove i šerafice da ih ispoliraju i kromiraju. cijenu još ne znam ali okvorno su mi rekli da ce poliranje koštati oko 1500kn, kromiranje 500kn i još od 1kn-5kn po šerafu!
instantno sam prepolovio stvari za kromiranje! pola dijelova koji su fora i vide se sam ostavio na kromiranju a drugu polovicu odnio na cincanje i plastificiranje.
toliko za sada.
BTW - Cooper je i dalje u dijelovima, još ništa nisam poceo slagati a zacrtao sam si da mi auto mora biti gotov 1.7. jer 20.7. putujemo u Dansku na International Mini Meeting! kaj mislite jel imam kakve šanse?
